I have a RM502Q-AE module on a Sixfab 5G module.
I’m using the module with an opencell sim and attempting to connect to an open air network implementation. I need RM500QGLABR11A06M4G firmware or later. Is version equivalent between RM502Q and RM500Q modems? I currently have RM502QAEAAR11A04M4G but I’m not sure how to compare the versions to know if I need a new firmware.
Next, can I use Qlog to capture output from the device? If so, where can I get a copy and the instructions to use it? The module fails to connect to the 5g network (other devices do).
Also, I want to capture the received signal for DSP analysis specifically for analyzing reflected signals. Is there a way to capture the stream from the module?
