Hallo, according to https://twitter.com/Quectel_IoT/status/1487096932111634432 the module is certified but I’m unable to connect using Windows 11 with driver V2.2 from https://www.quectel.com/download/quectel_lte5g_windows_usb_driver_v2-1-2. With MBN AutoSel enabled there is no service. When manually switching to the generic ROW_Generic_3GPP_PTCRB_GCF MBN I have service but unable to connect. APN is correct and worked with a EM120R-GL module. I tried firmware RM502QAEAAR11A04M4G_01.004.01.004 and RM502QAEAAR13A02M4G_01.001.01.001 with the same result.
Update:
Apparently the Windows APN setting has no effect, what worked for me was setting the modem provisioned profile like this: AT+CGDCONT=1,"IPV4V6","insert-apn-here","0.0.0.0",0,0. After a reset I was able to connect via the Default APN in Windows.
