Hi there!
I have a RM502QAEAAR11A02M4G (firmware revision listed as well) and wanted to know if there is a newer firmware version available for this.
If not, then I need help understanding why when I enable QMI (as it is by default) I can not stay connected to my carrier (T-Mobile). It will connect, remain connected for ~15 seconds, and then disconnect. MBIM works OK, but I still experience intermittent disconnects, and it seems to cause other issues (like some phones can’t enable WiFi calling).
Thanks in advance!
Dear Sir,
Thanks for your question.
R11A02 is the latest. please have a try with QMI_WWAN driver and QConnectManager. Quectel_LTE&5G_Linux_USB_Driver_User_Guide_V2.0.pdf (564.5 KB)
by the way,in order to better support you, please help to answer below questions, thanks in advance.
Company name and located city:
Project name (so we can refer to it in the future):
Application type:
Estimated Annual Units (for series production):
Project timeline:
Current status:
From which distributor do you buy Quectel modules & EVB kits?
Do you have EVB kit for this application?
