RM502Q-AE Firmware, Windows Drivers & Flashing Utility
I would like the current firmware for my Quectel RM502Q-AE, currently I am on version RM502QAEAAR11A02M4G
can you please send me the latest firmware, drivers, and tools to flash? I am using Windows 10
Hello can you please send the latest firmware, drivers, and tools to flash as well for me for RM502Q-AE? This is for Windows 11. Thanks in advance
I have sent them to your email,pls check
Hi can you please send them to me too?
I have sent them to you by message,pls check
Could you also send me a copy? Thanks!
Can you share the latest firmware for RM502Q-AE R13
RM502QAEAAR13A02M4G. Thanks
I have sent them to you by email,pls check
I have sent it to you by email,pls check
Got it, thanks! That was quick.
I’m also looking for the latest drivers and flashing utility for Windows and (if applicable) Linux and (again, if applicable) OS X. Can they be sent to me as well? Thank you!
Hi, I set RM502Q-AE to RNDIS, could you share the driver in windows version with me to change it back?
Or how I can reset all settings back to factory default?
Thanks for your support always.
Can I get also latest drivers and firmware?
Thanks :slight_smile:
Can you also send me MBIM driver?
Good day!
Please advise if a firmware update is available:
ATI
RM502Q-AE
Revision: RM502QAEAAR11A04M4G
If a newer firmware is available, please send me the latest firmware and the tool to flash the firmware, for Windows 10.
Thank you!
