RM502Q-AE ethernet mode IPA driver issues
When using this device connected to a convexa B1300, I found a strange anomaly from ipa3_wan_ioctl. The connection randomly drops on the WAN of the convexa B1300, and the only way to get the link up again is to either set a static IP (but the issue occurs later on) or renew the DHCP lease and obtain a new IP address. This issue doesn’t happen on USB (ECM, usbnet=1).
I will attach logs and AT+QGMR
at+qgmr
RM502QAEAAR13A04M4G_01.203.01.203
log_rm502.txt (116.6 KB)
Dear @Alessandro
When found the connection drop, is it possible to create a new connection on your host? Or connect automatically.
Yes, I have to manually reset the interface on the convexa B1300 to force a local IP change
Dear @Alessandro
Actually, it need log for analysis.
Is it possible on your side?
What logging application do you have or want to use? Provide the software and the specification on how to use it.
@silvia i’m waiting for additional instructions on what software to use to obtain the logs you want
Dear @Alessandro
What is your IPA driver? From linux driver or others, it seems IPA driver is not from us.
