Hello, I’m trying to change sim slot but my RM502Q-AE with firmware:
RM502QAEAAR13A04M4G
can’t switch slot:
Can you help me @Kerr.Yang-Q @herbert.pan-Q @silvia
RM502QAEAAR13A04M4G
can’t switch slot:
I’ve also tested AT+CFUN=1,1 after asking AT+QUIMSLOT=2 but gets back to 1
Dear @Josh
Due to RM502Q-AE only support single SIM. Please note this.
Thanks, do you please have the latest Qfirehose and latest firmware for RM502Q-AE ? Mine is stuck in fastboot and when issuing fastboot boot sdxprairie-boot.img it comes back to fastboot after some time… I want to try to put it in EDL mode and try to flash the full firmware files by making it go back to stock…
Dear @Josh
What did you do with your module?
Please contact with your provider next time, they have access to get the latest firmware and tool.
I did nothing. I ordere it and it seems that has NAND issue. Fastboot boot sdxprairie-boot.img boots the module correctly. Flashing it doesn’t solve the issue for longer than 3 days before going back to fastboot if the module isn’t attached to power. I would like to send the module back to Quectel for inspection and get a replacement, seems this is an isolated issue of the module itself.
