RM500U-CNV in NCM mode - need quectel-CM with NCM support
I need quectel-CM source which supports NCM mode for the following module.
RM500U-CNV
Revision: RM500UCNVCAR03A11M2G
You can set NCM mode with
AT+QCFG=”usbnet”,5
Dear @vijay
I have sent latest version to you via Message, please try.
it is working in NCM mode, but i have to use udhcp to get ipv4 ip.
ipv6 works through router advertisent, need to enable that using sysfs node.
Like dmi mode in quectel-CM where IP is assigned directly without help from other binaries. I am expecting similar support for NCM mode from quectel-CM. Let me check the new one and see if it supports.
