I’m using an RM500U-CNV on a Waveshare 5G M.2 to Gigabit ETH board (RTL8125) as a standalone router (AT+QCFG=“nat”,2, “ethernet”,1, “pcie/mode”,1, “usbnet”,5). It works well: 5G NSA on n78 with LTE B3 as anchor.
Module details:
- ATI revision: RM500UCNVAAR03A10M2G_01.001.01.001
- AT+QADBKEY? returns: PCEB03_17_25_24
- AT+QCFG=“usbcfg” returns: 0x2c7c,0x0900,1,1,1,1,1,0,0
Could you please help with the following?
- The ADB passcode for the key above.
- The latest firmware for the RM500U-CNV, with release notes, plus the flashing tool and the AT commands manual for this firmware.
- Does any RM500U-CNV firmware support sending AT commands over the Ethernet port (like AT+QETH=“eth_at” on the RM50xQ series)? On my firmware, AT+QETH=? only lists “speed”. The board will sit away from any USB host, so AT over Ethernet would let me manage it remotely.
- Which position in AT+QCFG=“usbcfg” enables ADB, and which one the USB audio (UAC) interface? With AT+QPCMV=1,0 during a call, one USB serial port outputs several multiplexed 16 kHz PCM streams mixed with trace data, so I’d like to know whether UAC voice is supported on this firmware.
Thank you!
