I try to use the AT commands to get some network and signal info from my RM500QGL modem connected to OAI gNB in SA mode.
AT+QENG="servingcell"
gives me:
+QENG: "servingcell","NOCONN","NR5G-SA","TDD", 001,01,E00,0,1,663264,77,12,-85,-11,20,1,-
…according to manual In SA mode:
+QENG: "servingcell",<state>,"NR5G-SA",<duplex_mode>,<MCC>,<MNC>,<cellID>,<PCID>,<TAC>,<ARFCN>,<band>,<NR_DL_bandwidth>,<RSRP>,<RSRQ>,<SINR>,<tx_power>,<srxlev>
I have some questions here:
-“NOCONN” should mean that the module is registered but in idle state, but this is given also when the module transmit the data actively
-the value for tx_power is decribed in the manual as follows: “TX power value in 1/10 dBm. It is the maximum of all UL channel TX power. The <tx_power> value is only meaningful when the device is in traffic.” (the upper was given in traffic)
… so does my “1” value here for tx_power really mean the power of 0.1dBm?.. can this value be trusted, isnt that a little low? And if yes, is there any way to force the modem to raise the power manually?
My setup is more or less like this:
except I use n310 USRP istead.
One of problems I experience is rather poor UPlink performance (low MCS, etc…). So Im tring to figure out what might be wrong.
Thank in advance for any reply.
Jan
