Ares
#1
hi, when we try the AT commands to check the signal, we found QSINR did not show MT service mode as QRSRP did, may we know why?
[root@ironos1 ~]# run_at_cmd -c “AT+QRSRP”
AT+QRSRP
+QRSRP: -92,-96,-97,-95,NR5G
[root@ironos1 ~]# run_at_cmd -c “AT+QSINR”
AT+QSINR
+QSINR:24,22,16,18
[root@ironos1 ~]# run_at_cmd -c “ATI”
ATI
RM500Q-GL
Revision: RM500QGLABR11A03M4G
[root@ironos1 ~]#
Dear Sir,
Please use R11A05 firmware to test it as below, thanks.
Ares
#3
Hi Peter,
Thanks for the quick response!
Can you share with us where can we find the release notes of the new firmware R11A05?
Best Regards!
Hi Ares,
Here you are. You also can contact our local FAE or distributor to get it.Thanks!
Quectel_RM500Q-GL-AB_Firmware_Release_Notes_V1105_01.001.01.001.pdf (984.2 KB)
thanks for the awesome information.
thanks my issue has been fixed.
