RM500Q-GL, RM502Q-GL - AT+QSCAN command
Hello.
Are there any plans to expand the capabilities of the AT+QSCAN command? Interested in adding to the response information on LAC and cell ID?
Already replied you via mail, please check it , thanks!
Hi Peter,
Can you please tell me which 5G module will be compatible with India?
Also, QSCAN command works without a SIM card? like AT+QOPS works in 4G?
Dear Sir,
Which footprint do you prefer to, LGA or M.2?
If M.2, RM500Q-AE will be recommended.
About your second question, yes, QSCAN can work without simcard.
Hi Peter,
Thanks for the information.
Please refer to freq. and band information as used in India for 5G
I have the following queries…
  1. Which 5G module will support this freq. and band configuration
  2. What is the difference between both modules?
  3. The 4G AT+QOPS like exact output can be obtained from 5G modules? (i.e. 5G module can be used to get 4G as well as 5G network information)
Regards
    [Quectel]They are n28,n5,n3,n78.
    but for 26GHz, it is for mmW band, not for sub6G. Our mmW module can support it.
    [Quectel]which modules do you mean?
    [Peter]We recommend QSCAN, it also can obtain LTE nearby cells.
Hi Peter,
By modules, I meant RM500Q-GL & RM500Q-AE (Both M.2)
What are the differences between them and for India which will be best suitable?
about 26GHz, which module can work?
Regards
[Quectel]RM500Q-AE will be better since it can support more ENDC combinations.
[Quectel]RM510Q can support,here the spec is.
Quectel_RM510Q-GL_5G_Specification_V1.1.pdf (423.8 KB)
Hi Peter,
Lastly, please clarify…
  1. For the bands requirement (refer to. previously attached file), RM510Q-GL will cover ALL bands, or do I have to use both modules, RM510Q-GL and RM500Q-AE?
  2. RM510Q-GL supports QSCAN without SIM card?
Regards
    [Quectel]RM510Q-GL can support all band you mentioned except E band(71-76/81-86 GHz).
    [/quote]
    [Quectel]Yes.
Hi Peter,
A very happy new year to you :slight_smile:
I am ordering the RM510Q-GL module for eval purposes, so can you please provide the latest AT manual, firmware, drivers, etc…
Thanks a lot!
Dear Ketan,
Happy new year:)
Since the AT manual,firmware and drivers are so big that I can’t upload them here.
May I have below information,so I can ask our related colleague to send to you via mail.
  • Company name and located city:
  • Project name (so we can refer to it in the future):
  • Application type:
  • Estimated Annual Units (for series production):
  • Project timeline:
  • Current status:
  • From which distributor do you buy Quectel modules & EVB kits?
  • Do you have EVB kit for this application?
Company name and located city: Ketan Computers, India (Mumbai City)
Project name (so we can refer to it in the future): Getting 5G Cell IDs
Application type: Utility
Estimated Annual Units (for series production): Less than 500 since it is very use/domain-specific
Project timeline: If eval success, then ready to implement
Current status: Eval
From which distributor do you buy Quectel modules & EVB kits? Emax Electronic Co. Ltd, Hong Kong
Do you have EVB kit for this application? No
Hi Peter,
Still, there is no response from local FAE :frowning:
Regards
Dear Sir,
His contact window as below, thanks!
Hi Peter,
I request if you can at least provide the latest AT manual for the same.
Already sent you via mail, please check, thanks!
HI,
i wanted to know how to enable QSCAN funktionality in RM500Q-GL. I can grab only this:
AT+QSCAN=?
ERROR
Info about this module:
ATI
RM500QGL
Revision: RM500QGLAAR01A01M4G_BETA_20200316F
i can share info about the company in priv message or via email.
kind regards,
Dominik
Dear Dominik,
From the module version you sent, it is engineer sample and quite old, please contact our sales to buy commercial samples, please kindly note it, thanks!
Thank you for reply. Could you confirm that RM500Q-GL is able to do QSCAN in commercial sample? Could you share the AT commands manual where QSCAN is described?
kind regards,
Dominik
