I have recently purchased a RM500QGL_VH (RM500QGLABR10A02M4G) module.
The module is connected to an ARMv8 SBC running linux over usb.
The sim card was taking from a huawei CPE(H112-370).
The carrier is “3 UK” (wuawei base station in N77,N78).
I am using qmi_wwan in linux 5.8.9-2-ARCH.
I have tried using ModemManager (recent master) and libqmi (1.26.6) but cannot
seem to get the card working in 5g mode.
I have tried a few different combinations of settings:
NR5G only – unable to register on any network
NR5G:LTE – lte is working but no 5g
Before I ask the provider for a new SIM card is there some way to:
- Reset firmware to factory defaults
- magic QMI command to poke the 5g radio
- Upgrade module firmware/config to a newer version
Anything else I should try?
Thank you kindly,
John
Here is some modem session:
+CREG: 2
+CREG: 1,"1447","141906", 7
AT+COPS?
+COPS: 0,1,"3",7
AT+COPS=4,1,"3",13
AT+COPS?
+COPS: 0,1,"3",7
ATI
RM500Q-GL
Revision: RM500QGLABR10A02M4G
AT+CFUN?
+CFUN: 1
AT+CPAS
+CPAS: 0
AT+QCFG="data_interface"
+QCFG: "data_interface",0,0
AT+CREG?
+CREG: 2,1
AT+CSQ
+CSQ: 31,99
AT+CPOL?
+CME ERROR: 3
AT+QENG="servingcell"
+QENG: "servingcell","NOCONN","LTE","FDD",234,20,141900,312,1392,3,4,4,3EE,-83,-13,-51,11,255,-32768,42
AT+QENG="neighbourcell"
AT+QCAINFO
AT+QNWCFG="lte_csi"
+QNWCFG: "lte_csi",0,1,7,11
AT+QNWCFG="nr5g_csi"
+QNWCFG: "nr5g_csi",0,0,0,0
AT+QNWPREFCFG= "nsa_nr5g_band"
+QNWPREFCFG: "nsa_nr5g_band",1:3:7:20:77:78:79
AT+QNWPREFCFG= "nr5g_band"
+QNWPREFCFG: "nr5g_band",1:3:7:20:77:78:79
AT+QNWPREFCFG="policy_band"
ERROR
AT+QNWPREFCFG="rat_acq_order"
ERROR
AT+QNWPREFCFG="nr5g_disable_mode",0
ERROR
AT+QADC=?
+QADC: (0,1)
AT+QADC=0
+QADC: 1,84212
AT+QADC=1
+QADC: 1,87262
AT+QSCLK?
+QSCLK: 0,0
AT+QTEMP
+QTEMP:"qfe_wtr_pa0","40"
+QTEMP:"qfe_wtr_pa1","41"
+QTEMP:"qfe_wtr_pa2","37"
+QTEMP:"qfe_wtr_pa3","35"
+QTEMP:"aoss0-usr","37"
+QTEMP:"mdm-q6-usr","37"
+QTEMP:"ipa-usr","37"
+QTEMP:"cpu0-a7-usr","37"
+QTEMP:"mdm-5g-usr","37"
+QTEMP:"mdm-vpe-usr","37"
+QTEMP:"mdm-core-usr","37"
+QTEMP:"xo-therm-usr","37"
+QTEMP:"sdx-case-therm-usr","37"
Without any more detail it looks like pa for 5g radio is completely idle
Here is some qmicli commands:
[root@alarm ~]# bash -x info.sh
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-manufacturer
[/dev/cdc-wdm0] Device manufacturer retrieved:
Manufacturer: 'Quectel'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-model
[/dev/cdc-wdm0] Device model retrieved:
Model: 'RM500QGL_VH'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-revision
[/dev/cdc-wdm0] Device revision retrieved:
Revision: 'RM500QGLABR10A02M4G'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-hardware-revision
[/dev/cdc-wdm0] Hardware revision retrieved:
Revision: '20000'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-software-version
[/dev/cdc-wdm0] Software version: RM500QGLABR10A02M4G
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-power-state
[/dev/cdc-wdm0] Device power state retrieved:
Power state: 'external-source'
Battery level: '0 %'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-operating-mode
[/dev/cdc-wdm0] Operating mode retrieved:
Mode: 'online'
HW restricted: 'no'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --dms-get-band-capabilities
[/dev/cdc-wdm0] Device band capabilities retrieved:
Bands: 'wcdma-2100, wcdma-pcs-1900, wcdma-dcs-1800, wcdma-1700-us, wcdma-850-us, wcdma-800, wcdma-900, wcdma-850-japan'
LTE bands: '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 43'
LTE bands (extended): '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 43, 46, 48, 66, 71'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-technology-preference
[/dev/cdc-wdm0] Successfully got technology preference
Active: '3gpp, lte', duration: 'permanent'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-system-selection-preference
[/dev/cdc-wdm0] Successfully got system selection preference
Emergency mode: 'no'
Mode preference: 'lte, 5gnr'
Disabled modes: '(null)'
Band preference: 'bc-0-a-system, bc-0-b-system, bc-1-all-blocks, bc-2, bc-3-a-system, bc-4-all-blocks, bc-5-all-blocks, gsm-dcs-1800, gsm-900-extended, gsm-900-primary, bc-6, bc-7, bc-8, bc-9, bc-10, bc-11, wcdma-2100, wcdma-pcs-1900, wcdma-dcs-1800, wcdma-1700-us, wcdma-850-us, wcdma-800, wcdma-900, wcdma-850-japan'
LTE band preference: '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 43'
LTE band preference (extended): '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 43, 46, 48, 66, 71'
TD-SCDMA band preference: 'a, b, c, d, e, f'
Roaming preference: 'any'
Network selection preference: 'automatic'
Service domain preference: 'cs-ps'
GSM/WCDMA acquisition order preference: 'automatic'
Usage preference: 'data-centric'
Voice domain preference: 'ps-preferred'
Registration restriction: 'unrestricted'
Acquisition order preference: 5gnr, lte, umts
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-cell-location-info
[/dev/cdc-wdm0] Successfully got cell location info
Intrafrequency LTE Info
UE In Idle: 'yes'
PLMN: '23420'
Tracking Area Code: '1006'
Global Cell ID: '1317120'
EUTRA Absolute RF Channel Number: '0' (E-UTRA band 1: 2100)
Serving Cell ID: '107'
Cell Reselection Priority: '0'
S Non Intra Search Threshold: '0'
Serving Cell Low Threshold: '0'
S Intra Search Threshold: '0'
Cell [0]:
Physical Cell ID: '0'
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Cell Selection RX Level: '0'
Cell [1]:
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Cell [2]:
Physical Cell ID: '2566'
RSRQ: '0.4' dB
RSRP: '1587.2' dBm
RSSI: '0.0' dBm
Cell Selection RX Level: '-1'
Cell [3]:
Physical Cell ID: '3927'
RSRQ: '79.4' dB
RSRP: '648.3' dBm
RSSI: '79.4' dBm
Cell [4]:
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Cell [5]:
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Cell [6]:
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Cell [7]:
RSRQ: '0.0' dB
RSRP: '0.0' dBm
RSSI: '0.0' dBm
Interfrequency LTE Info
UE In Idle: 'yes'
LTE Info Neighboring GSM
UE In Idle: 'yes'
LTE Info Neighboring WCDMA
UE In Idle: 'yes'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-operator-name
[/dev/cdc-wdm0] Successfully got operator name data
PLMN List:
MCC/MNC: '234-20' LAC Range: 0->65279 PNN Record: 1
MCC/MNC: '234-33' LAC Range: 0->65279 PNN Record: 1
MCC/MNC: '272-05' LAC Range: 0->65279 PNN Record: 2
MCC/MNC: '272-02' LAC Range: 0->65279 PNN Record: 2
PLMN Names:
0: '3' ('') Country: 'initials-do-not-add'
1: '3 IRL' ('') Country: 'initials-do-not-add'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-lte-cphy-ca-info
error: couldn't get carrier aggregation info: QMI protocol error (74): 'InformationUnavailable'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-rf-band-info
[/dev/cdc-wdm0] Successfully got RF band info
Band Information:
Radio Interface: 'lte'
Active Band Class: 'eutran-3'
Active Channel: '1392'
Band Information (Extended):
Bandwidth:
Bandwidth: '15'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-signal-strength
[/dev/cdc-wdm0] Successfully got signal strength
Current:
Network 'lte': '-50 dBm'
RSSI:
ECIO:
Network 'lte': '-2.5 dBm'
IO: '-106 dBm'
SINR (8): '9.0 dB'
RSRQ:
Network 'lte': '-12 dB'
SNR:
Network 'lte': '3.6 dB'
RSRP:
Network 'lte': '-81 dBm'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-signal-info
[/dev/cdc-wdm0] Successfully got signal info
LTE:
RSSI: '-50 dBm'
RSRQ: '-12 dB'
RSRP: '-81 dBm'
SNR: '3.6 dB'
5G:
RSRP: '-32768 dBm'
SNR: '-3276.8 dB'
RSRQ: '-32768 dB'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-tx-rx-info=lte
[/dev/cdc-wdm0] Successfully got TX/RX info
RX Chain 0:
Radio tuned: 'yes'
Power: '-51.2 dBm'
ECIO: '-13.5 dB'
RSRP: '-83.4 dBm'
Phase: '0.00 degrees'
RX Chain 1:
Radio tuned: 'yes'
Power: '-60.5 dBm'
ECIO: '-14.9 dB'
RSRP: '-94.2 dBm'
TX:
In traffic: 'no'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-tx-rx-info=5gnr
error: couldn't get TX/RX info: QMI protocol error (93): 'NoRadio'
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-home-network
[/dev/cdc-wdm0] Successfully got home network:
Home network:
MCC: '234'
MNC: '20'
Description: '3 UK'
Network name source: se13
+ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-serving-system
[/dev/cdc-wdm0] Successfully got serving system:
Registration state: 'registered'
CS: 'attached'
PS: 'attached'
Selected network: '3gpp'
Radio interfaces: '1'
[0]: 'lte'
Roaming status: 'off'
Data service capabilities: '1'
[0]: 'lte'
Current PLMN:
MCC: '234'
MNC: '20'
Description: '3'
Roaming indicators: '1'
[0]: 'off' (lte)
3GPP cell ID: '1317120'
Detailed status:
Status: 'available'
Capability: 'cs-ps'
HDR Status: 'none'
HDR Hybrid: 'no'
Forbidden: 'no'
LTE tracking area code: '1006'
Full operator code info:
MCC: '234'
MNC: '20'
MNC with PCS digit: 'no'
