RM500Q-GL Not Sending RA Proc Msg3 After Connecting to gNB
I am experiencing an issue with my Quectel RM500Q-GL module. After connecting to the gNB, it does not send RA Proc Msg3. The configuration settings of this module are identical to another RM500Q-GL that is working perfectly fine in the same setup.
Could you please assist in troubleshooting this issue? Let me know if you need any logs or additional information.
Looking forward to your guidance.
Dear @NR5GSA
Did you see any Msg2 on your side?
It is better to capture log.
Hi , @silvia
Thanks for the reply ,
Yes, I can see Msg2 being received on both of my Quectel modules—both the one that connects perfectly and the one that is currently having issues.
The module that is not working now used to function perfectly fine before it started behaving strangely a few days ago. Flashing the latest firmware again also did not fix the issue
Dear @NR5GSA
Is it possible to capture log via USB on your side? If yes, please include AT+CFUN=0/AT+CFUN=1.
