Hi all,
Recently purchased RM500Q-GL for use in Mikrotik RBM11G router.
Purchased because it stated it can do B3+B1+B32 aggregation
However, on testing it is only doing 3+32 or 1+32, but not 3+1+32. I know mast node can do 3CA as I have confirmed with NR5103E Router.
Any ideas?
Dear @Arthur_Dent
Yes, RM500Q-GL supports CA_1A-3A-32A, did you confirm if the carrier support the combination or not?
I can confirm carrier supports this combination and that mast is broadcast this combination.
Have also previously used Zyxel NR5103E router which also supported this combination and aggregated all 3.
Dear @Arthur_Dent
Did you use the latest firmware to try?or share your test firmware to me.
RM500QGLABR11A03M4G is my current firmware.
I have RM500QGLABR13A02M4G_01.200.01.200 firmware to load but not sure how to install.
I’m also having issues getting the modem to work with the router in PCIe mode - I’ve tried setting data_interface to 1,0 and lost the interface in Mikrotik router.
changed modem from EP mode and it’s now in PCIe mode on the mikrotik router and aggregating
Dear @Arthur_Dent
Actually, I can share upgrade tool of Quectel to you, but I don’t know how to use with Mikrotik router.
