I have two identical machines running ubuntu 22.04, they were cloned from the same source. But I don’t know why they are loaded with different driver (cdc_mbim and qmi_wwan). However the machine loaded with qmi_wwan failed to register sim card and no 5G option.
“qmi_wwan”
mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 513c9d8a61c5191985aa8067cf602e7270ca3f71
Hardware | manufacturer: Quectel
| model: RM500Q-GL
| firmware revision: RM500QGLABR13A02M4G
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 863305041810838
System | device: /sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1
| drivers: option, qmi_wwan
| plugin: quectel
| primary port: ttyUSB1
| ports: ttyUSB0 (qcdm), ttyUSB1 (at), ttyUSB2 (at), wwan0 (ignored)
Status | unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: enabled
| power state: on
| signal quality: 0% (recent)
Modes | supported: allowed: 2g, 3g, 4g; preferred: none
| current: allowed: 2g, 3g, 4g; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 863305041810838
| registration: idle
| packet service state: detached
3GPP EPS | ue mode of operation: csps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=0800 Rev= 4.14
S: Manufacturer=Quectel
S: Product=RM500Q-GL
S: SerialNumber=2d1b3904
C:* #Ifs= 5 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=option
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=40 Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=88(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=8e(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0f(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
“cdc_mbim”
mmcli -m 0
| device id: 0ce762fffdc1c77e68def2f092d5fd5e87154d18
| model: RM500Q-GL
| carrier config: ROW_Commercial
| carrier config revision: 0A010809
| h/w revision: RM500Q-GL
| supported: gsm-umts, lte, 5gnr, tds
| current: gsm-umts, lte, 5gnr, tds
| equipment id: 863305041869883
| drivers: option, cdc_mbim
| plugin: quectel
| primary port: cdc-wdm1
| ports: cdc-wdm1 (mbim), ttyUSB0 (qcdm), ttyUSB1 (at),
| ttyUSB2 (at), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin2 (3)
| state: connected
| power state: on
| access tech: lte, 5gnr
| signal quality: 30% (recent)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 5g; preferred: none
| allowed: 4g, 5g; preferred: 5g
| allowed: 4g, 5g; preferred: 4g
| allowed: 3g, 5g; preferred: 5g
| allowed: 3g, 5g; preferred: 3g
| allowed: 3g, 4g, 5g; preferred: 5g
| allowed: 3g, 4g, 5g; preferred: 4g
| allowed: 3g, 4g, 5g; preferred: 3g
| current: allowed: 3g, 4g, 5g; preferred: 5g
Bands | supported: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
| utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
| eutran-8, eutran-12, eutran-13, eutran-14, eutran-17, eutran-18,
| eutran-19, eutran-20, eutran-25, eutran-26, eutran-28, eutran-29,
| eutran-30, eutran-32, eutran-34, eutran-38, eutran-39, eutran-40,
| eutran-41, eutran-42, eutran-43, eutran-46, eutran-48, eutran-66,
| eutran-71, utran-19, ngran-1, ngran-2, ngran-3, ngran-5, ngran-7,
| ngran-8, ngran-12, ngran-20, ngran-25, ngran-28, ngran-38, ngran-40,
| ngran-41, ngran-48, ngran-66, ngran-71, ngran-77, ngran-78, ngran-79
| current: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
3GPP | imei: 863305041869883
| enabled locks: fixed-dialing
| operator id: 45400
| operator name: MORE Mobile
| registration: home
| packet service state: attached
| initial bearer path: /org/freedesktop/ModemManager1/Bearer/0
| initial bearer ip type: ipv4v6
3GPP 5GNR | mico mode: unsupported
| drx cycle: unsupported
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/1
S: SerialNumber=112aed40
C:* #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=500mA
A: FirstIf#= 4 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00
I:* If#= 4 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim
E: Ad=88(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
I: If#= 5 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I:* If#= 5 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
