We are testing slicing with S-NSSAI information. After running the AT commands, it is connecting to the network and in the amf log we can see the S-NSSAI information which is correct and the connection is successful. However, when I put this command (AT+CGDCONT=1, “IP”,“internet”, “0.0.0.0”,“01.0186a0”), it shows an ERROR. Surprisingly the connection is successful. Could anyone please describe me the reason?
The above-mentioned case as yesterday and today there is no connection. Attached is the command along with the Error. Unfortunately, the modem was not connected with the network even without slicing today. But, when we tested with a new SIM card it got the 5G connection. Then, tried with the slicing parameter then no luck today.
Could you please help in this case so that we can solve the issue?
