I have downloaded drivers and flashed the modem to the latest firmware. I can connect through qcom and have set at+qcfg=“usbnet”,1. Set apn set IMEI and nothing.
At+qeng=“servingcell” shows limserv and my computer doesn’t even recognize it as a modem. I have read and read but it seams I am the only person to have this problem. Did I get a bad module or is there something I am missing?
Dear @Hogtiednaked
Please share a picture of device manager.
Which driver did you install?
For limsrv, did you test with another SIM card?
I keep getting +QLWURC: “bootstrap”,”failed”,100
What does that mean?
Dear @Hogtiednaked
+QLWURC is used for LwM2M.
Do you install the module into PC directly?
Please check the AT command below:
AT+QMBNCFG=“List”
no it is in an m2m ethernet enclosure
[2025-01-09 06:28:42:385_S:] at+qmbncfg=“list”
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,0,1,1,“CDMAless-Verizon”,0x0A010126,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,1,0,0,“ROW_Commercial”,0x0A010809,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,2,0,0,“TEF_Spain_Commercial”,0x0A010C00,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,3,0,0,“FirstNet”,0x0A015300,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,4,0,0,“Rogers_Canada”,0x0A014800,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,5,0,0,“Bell_Canada”,0x0A014700,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,6,0,0,“Telus_Canada”,0x0A014900,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,7,0,0,“Commercial-Sprint”,0x0A010204,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,8,0,0,“Commercial-TMO”,0x0A01050F,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,9,0,0,“VoLTE-ATT”,0x0A010335,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,10,0,0,“CDMAless_Private-Verizon”,0x0A01FD28,202312291
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,11,0,0,“Swiss-Comm”,0x0A010411,202404081
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,12,0,0,“Telia_Sweden”,0x0A012400,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,13,0,0,“TIM_Italy_Commercial”,0x0A012B00,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,14,0,0,“France-Commercial-Orange”,0x0A010B21,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,15,0,0,“Commercial-DT-VOLTE”,0x0A011F1F,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,16,0,0,“Germany-VoLTE-Vodafone”,0x0A010449,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,17,0,0,“UK-VoLTE-Vodafone”,0x0A010426,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,18,0,0,“Commercial-EE”,0x0A01220B,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,19,0,0,“Optus_Australia_Commercial”,0x0A014400,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,20,0,0,“Telstra_Australia_Commercial”,0x0A010F00,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,21,0,0,“Commercial-LGU”,0x0A012608,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,22,0,0,“Commercial-KT”,0x0A01280B,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,23,0,0,“Commercial-SKT”,0x0A01270A,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,24,0,0,“Commercial-Reliance”,0x0A011B0C,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,25,0,0,“Commercial-SBM”,0x0A011C0B,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,26,0,0,“Commercial-KDDI”,0x0A010709,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,27,0,0,“Commercial-DCM”,0x0A010D0D,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,28,0,0,“CBN_Commercial”,0x0A012300,202404081
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,29,0,0,“VoLTE-CU”,0x0A011561,202307281
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,30,0,0,“VoLTE_OPNMKT_CT”,0x0A0113E0,202302241
[2025-01-09 06:28:42:511_R:] +QMBNCFG: “List”,31,0,0,“Volte_OpenMkt-Commercial-CMCC”,0x0A012010,202307281
[2025-01-09 06:28:42:511_R:] OK
Hi. I live in Russia, this module does not work. LIMSRV always writes that it cannot connect to Russian networks. It’s a pity that Quectel did this to people, it’s a pity.
Because it is a Qualcomm modem. It’s the US government ordering their compnies to ban Russia from their products. I hope you can return it and get your money back.
The firmware update log states the reason.
RM551E might be the same.
You may be able to return it for a refund and find a non-Qualcomm platform alternative.
Dear @Hogtiednaked
Could you try to use Row and test again as follow?
AT+QMBNCFG=“Deactivate”
AT+QMBNCFG=“Autosel”,0
AT+QMBNCFG=“Select”,“ROW_Commercial”
AT+CFUN=0
AT+CFUN=1
Now I’m getting +QLWURC:”pdp active”,”failed”,”ims”
Dear @Hogtiednaked
Please confirm if you use LwM2M feature, QLWURC is related with this.
After configur row, did it register?
AT+QENG=“servingcell”
[2025-01-13 14:07:50:638_R:] +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,311,480,2122816,22,66611,66,4,4,8702,-118,-20,-73,5,0,-,5
[2025-01-13 14:07:50:638_R:] OK
How do i know if LwM2M is turned on?
Dear @Hogtiednaked
Actually, the device has registered on LTE network.
For LwM2M, please check if youe MCU code had implemented the feature.
For RM551E, it doesn’t support this now.
I don’t know what the mcu code is.
Everything seems to be right. I can query the modem in device manager and get a response but it still does not show up as an internet option. I have uninstalled and reinstalled drivers a dozen times. Have tried different cables even a different enclosure. Still not able to get an internet connection to my computer.
Dear @Hogtiednaked
=>From this, you had register on LTE.
Did you have data call?
How can I make a data call?
Dear @Hogtiednaked
Did you try to use AT+QCFG=“usbnet”,0 ?
Which driver did you install?ECM or others? From the picture, it shows that the ECM driver didn’t install correctly.
yes i have tried all usbnet settings with 3 losing the at port and having to reassign a driver. The ecm driver i have is v1.0.
