Module: RG650E-EU,Current revision: RG650EEU00AAR01A04G8G.
installed in a MikroTik Chateau 5G R17 ax After a recent update the LTE link does not come up. The firmware has become corrupted due to an incomplete installation. Please provide the DFOTA delta package from A04G8G to A03G8G (or A02G8G), plus instructions for AT+QFOTADL
Update on my request above: the situation is worse than I first described.
Device: Quectel RG650E-EU in a MikroTik Chateau 5G R17 ax
the modem firmware update was interrupted and did not complete, and the firmware is now corrupted.
the LTE interface does not detect the SIM, AT commands get no response, and the usual MikroTik firmware-upgrade command does not fix it.
If this has to be handled through a distributor or a support ticket instead of the forum, please tell me which one.
Thank you.
Dear @A_user
You can try to upgrade again.
For Mikrotik device, please contact them and get support.
HelIo Silvia.
I have already tried upgrading again, and it does not work: the modem does not answer AT commands and the SIM is not detected.
I also contacted MikroTik. They told me to send the device back for repair, but that process takes 4 months.
The router is installed in a remote area where it is the only connection, and the site needs connectivity, so I cannot wait for a return.
The module itself is the problem: the firmware was corrupted by an interrupted update. Could you please provide me with The full firmware package for the RG650E-EU (A03G8G or A02G8G)
Thank you.
Dear @A_user
I have sent A03 to your email, please try.
