Thank you, Silvia.
I successfully installed the new firmware using QFlash v7.5. Unfortunately, the behavior remains the same. I still receive the error “QMI protocol error (48): InvalidArgument” when using --loc-follow-nmea, and “QMI protocol error (94): NotSupported” when running the --loc-get-nmea-types command.
Is there anything else I can try to resolve this issue?
For reference, here is the module information:
ATI
RG520N-LA
Revision: RG520NLADAR03A04M8G
I have tried to configure it with and without proxy. These are the commands I have used and the outputs:
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-get-operation-mode
Successfully retrieved operation mode: standalone
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-get-engine-lock
Successfully retrieved engine lock: none
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-get-nmea-types -v
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] opening device with flags 'proxy, auto, expect-indications'...
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] created endpoint
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 28
<<<<<< data = 01:1B:00:00:00:00:00:01:00:FF:10:00...
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 27
<<<<<< flags = 0x00
<<<<<< service = "ctl"
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = "none"
<<<<<< transaction = 1
<<<<<< tlv_length = 16
<<<<<< message = "Internal Proxy Open" (0xFF00)
<<<<<< TLV:
<<<<<< type = "Device Path" (0x01)
<<<<<< length = 13
<<<<<< value = 2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
<<<<<< translated = /dev/cdc-wdm0
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 19
<<<<<< data = 01:12:00:80:00:00:01:01:00:FF:07:00...
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 18
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = "response"
<<<<<< tlv_length = 7
<<<<<< TLV:
<<<<<< type = "Result" (0x02)
<<<<<< length = 4
<<<<<< value = 00:00:00:00
<<<<<< translated = SUCCESS
[19 Apr 2018, 05:27:49] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] assuming service 'loc' is supported...
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] allocating new client ID...
<<<<<< RAW:
<<<<<< length = 16
<<<<<< data = 01:0F:00:00:00:00:00:02:22:00:04:00...
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 2
<<<<<< tlv_length = 4
<<<<<< message = "Allocate CID" (0x0022)
<<<<<< TLV:
<<<<<< type = "Service" (0x01)
<<<<<< length = 1
<<<<<< value = 10
<<<<<< translated = loc
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:80:00:00:01:02:22:00:0C:00...
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< tlv_length = 12
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< type = "Allocation Info" (0x01)
<<<<<< length = 2
<<<<<< value = 10:02
<<<<<< translated = [ service = 'loc' cid = '2' ]
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] registered 'loc' (version unknown) client with ID '2'
<<<<<< RAW:
<<<<<< length = 13
<<<<<< data = 01:0C:00:00:10:02:00:01:00:3F:00:00...
<<<<<< QMUX:
<<<<<< length = 12
<<<<<< flags = 0x00
<<<<<< service = "loc"
<<<<<< client = 2
<<<<<< QMI:
<<<<<< tlv_length = 0
<<<<<< message = "Get NMEA Types" (0x003F)
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:10:02:02:01:00:3F:00:07...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 2
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< value = 01:00:5E:00
<<<<<< translated = FAILURE: NotSupported
error: could not get NMEA types: QMI protocol error (94): 'NotSupported'
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] releasing 'loc' client with flags 'release-cid'...
[19 Apr 2018, 05:27:49] [Debug] [/dev/cdc-wdm0] unregistered 'loc' client with ID '2'
<<<<<< RAW:
<<<<<< length = 17
<<<<<< data = 01:10:00:00:00:00:00:03:23:00:05:00...
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 3
<<<<<< tlv_length = 5
<<<<<< message = "Release CID" (0x0023)
<<<<<< TLV:
<<<<<< type = "Release Info" (0x01)
<<<<<< length = 2
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:80:00:00:01:03:23:00:0C:00...
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
[19 Apr 2018, 05:27:49] [Debug] Client released
[19 Apr 2018, 05:27:49] [Debug] Closed
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-start
[/dev/cdc-wdm0] Successfully started location tracking (session id 0)
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-follow-nmea -v
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] opening device with flags 'proxy, auto, expect-indications'...
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] created endpoint
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 28
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 27
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 13
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 19
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 18
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
[19 Apr 2018, 05:32:42] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] assuming service 'loc' is supported...
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] allocating new client ID...
<<<<<< RAW:
<<<<<< length = 16
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 1
<<<<<< value = 10
<<<<<< RAW:
<<<<<< length = 24
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] registered 'loc' (version unknown) client with ID '2'
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:00:10:02:00:01:00:21:00:0B...
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x00
<<<<<< client = 2
<<<<<< QMI:
<<<<<< tlv_length = 11
<<<<<< message = "Register Events" (0x0021)
<<<<<< TLV:
<<<<<< type = "Event Registration Mask" (0x01)
<<<<<< length = 8
<<<<<< value = 04:00:00:00:00:00:00:00
<<<<<< translated = nmea
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:10:02:02:01:00:21:00:07...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 2
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< value = 01:00:30:00
<<<<<< translated = FAILURE: InvalidArgument
error: could not register location tracking events: QMI protocol error (48): 'InvalidArgument'
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] releasing 'loc' client with flags 'release-cid'...
[19 Apr 2018, 05:32:42] [Debug] [/dev/cdc-wdm0] unregistered 'loc' client with ID '2'
<<<<<< RAW:
<<<<<< length = 17
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 2
<<<<<< RAW:
<<<<<< length = 24
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
[19 Apr 2018, 05:32:42] [Debug] Client released
[19 Apr 2018, 05:32:42] [Debug] Closed
root:~# qmicli -d /dev/cdc-wdm0 --device-open-proxy --loc-stop
[/dev/cdc-wdm0] Successfully stopped location tracking (session id 0)
The same comands without proxy:
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --loc-noop
[/dev/cdc-wdm0] Client ID not released:
Service: 'loc'
CID: '5'
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-get-nmea-types
Service: 'loc'
CID: '5'
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-get-nmea-types -v
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] opening device with flags 'auto, expect-indications'...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] created endpoint
[19 Apr 2018, 06:25:15] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[19 Apr 2018, 06:25:15] [Debug] Reusing CID '5'
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] assuming service 'loc' is supported...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] reusing client CID '5'...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] registered 'loc' (version unknown) client with ID '5'
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 13
<<<<<< data = 01:0C:00:00:10:05:00:01:00:3F:00:00...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 12
<<<<<< flags = 0x00
<<<<<< client = 5
<<<<<< QMI:
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:10:05:02:01:00:3F:00:07...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 5
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
Service: 'loc'
CID: '5'
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] releasing 'loc' client with flags 'none'...
[19 Apr 2018, 06:25:15] [Debug] [/dev/cdc-wdm0] unregistered 'loc' client with ID '5'
[19 Apr 2018, 06:25:15] [Debug] Client released
[19 Apr 2018, 06:25:15] [Debug] Closed
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-start
Service: 'loc'
CID: '5'
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-follow-nmea
Service: 'loc'
CID: '5'
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-follow-nmea -v
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] opening device with flags 'auto, expect-indications'...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] created endpoint
[19 Apr 2018, 06:26:16] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[19 Apr 2018, 06:26:16] [Debug] Reusing CID '5'
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] assuming service 'loc' is supported...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] reusing client CID '5'...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] registered 'loc' (version unknown) client with ID '5'
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:00:10:05:00:01:00:21:00:0B...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x00
<<<<<< client = 5
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 8
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:10:05:02:01:00:21:00:07...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 5
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
Service: 'loc'
CID: '5'
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] releasing 'loc' client with flags 'none'...
[19 Apr 2018, 06:26:16] [Debug] [/dev/cdc-wdm0] unregistered 'loc' client with ID '5'
[19 Apr 2018, 06:26:16] [Debug] Client released
[19 Apr 2018, 06:26:16] [Debug] Closed
root:~# qmicli -d /dev/cdc-wdm0 --client-no-release-cid --client-cid=5 --loc-stop
Service: 'loc'
CID: '5'
root:~# qmicli -d /dev/cdc-wdm0 --client-cid=5 --loc-noop
