I successfully restored the file, and 4G (LTE-A CA) is working properly now. However, the module still cannot connect to 5G NSA/SA at all—it remains stuck on 4G. Under the exact same environment (same SIM card, location, and Magyar Telekom network), my RM502Q-AE connects to 5G NSA without any issues.
This 5G connectivity issue was the original reason I attempted to update the firmware in the first place (which unfortunately led to the lost QCN).
Do you have any suggestions on how to resolve this? Is there an updated official firmware package or a specific NV/QCN setting for RG520N-EU that properly supports European 5G NSA (EN-DC)?
1. SA Setting: SA is not disabled on the device (nr5g_disable_mode is set to allow both / search mode is LTE:NR5G), but in my area Magyar Telekom only deploys 5G via NSA (EN-DC, n78).
2. MBN Configuration: The currently active MBN is Commercial-DT-VOLTE (automatically selected for Telekom MCC/MNC 21630). Under Commercial-DT-VOLTE, 4G CA works, but the module never establishes the 5G NR SCC.
I changed the search preference to 5G preferred (NR5G:LTE) and reconnected, but it makes no difference. The module is still stuck on 4G LTE-A (CA) and does not connect to 5G NSA.
Just to clarify: before I updated to the latest firmware—when the original factory QCN was still intact—this module already had the exact same problem (no 5G NSA, stuck on 4G). That was actually the very reason I tried updating the firmware in the first place. So the restored QCN is likely not the root cause.
