RG520F-EU SA CA n28+n78 - SCell deactivated after periodic PCell change to n78
RG520F-EU: SA CA n28+n78 - SCell deactivated after periodic PCell change to n78; how to disable SRS switching / lock PCell in connected mode?
Summary
MikroTik ATL 5G R16 (RG520F-EU, fw RG520FEUEAR03A08M4GX_01.300.01.300) on Movistar Spain 5G SA (PCell n28 10 MHz + DL-only SCell n78 100 MHz). Every 17 s the network moves the PCell to n78 for ~3 s and back; after the second event the n78 SCell is deactivated for good (DL 265-350 → 40-50 Mbps). Any cell lock that stops the events also leaves the SCell permanently deactivated. A ZTE MC8512 (MediaTek) holds the same CA for hours after disabling SRS Tx switching and applying a connected-mode PCell lock.
Questions
  1. Is there an AT command or NV/EFS item (AT+QNVFW recipe: path, value, format) to disable SRS antenna switching capability (srs-TxSwitch) on RG520F-EU, globally or for n78?
  2. Can the PCell be locked in connected mode (suppressing measurement reports / handover to n78) without detach and without deactivating an active SCell? Can AT+QNWLOCK=“common/5g” be applied without detach?
  3. Can n78 be prevented from being used as PCell while kept as DL SCell in CA_n28-n78 (e.g. capability control)?
  4. Is “SCell configured but never activated under cell lock” expected? What does the lock change in measurement reporting?
  5. Which logs do you need, and how can QXDM/DIAG logs be captured on this MikroTik unit?
Setup
  • Device: MikroTik ATL 5G R16 (board ATLGM), RouterOS 7.22. Modem Quectel RG520F-EU, fw A08 (same behaviour on previous RG520FEUEAR03A07M4GX).
  • MBN: ROW_Commercial (AutoSel 1); no Movistar/Telefonica profile in the list.
  • Settings: mode_pref NR5G, nr5g_band 28:78, 3gpp_rel R16,R16, nr5g_4mimo_enable 1, nr5g_cdrx 1.
  • Network: Movistar Spain (214-07), 5G SA. Site ~4 km away, outdoor directional antenna.
  • PCell n28: 10 MHz, NR-ARFCN 156510, SCS 15 kHz, PCI 523. RSRP -80..-82 dBm, SINR 3-7 dB.
  • SCell n78: 100 MHz, NR-ARFCN 636576, SCS 30 kHz, PCI 597 (DL-only, ul_configured 0). RSRP -85..-92 dBm, SINR 20-25 dB.
  • Goal: stable SA CA n28 (PCell) + n78 (SCell).
Observations without lock
Load: 4 parallel HTTP downloads from a PC behind the router, 30-45 s; state polled every ~3 s with AT+QCAINFO and RouterOS lte monitor.
  • After a fresh attach (AT+CFUN=4 / AT+CFUN=1) the SCell is activated immediately (QCAINFO scell_state 2), DL 265-350 Mbps.
  • Every 17 s exactly the network changes the PCell to n78 (PCI 597; sometimes 653 or 827 on the same ARFCN), n28 PCI 523 shown as SCC, and returns to n28 PCI 523 within ~3 s. Each event is a short data interruption (3-6 % ping loss at 200 ms interval). With +QNWCFG “rrc_state” URC enabled, URCs arrive in pairs at each event.
  • After the first event the SCell is still active. After the second it stays configured but deactivated (scell_state 1) indefinitely; DL 40-50 Mbps (n28 only); the 17 s events continue.
  • Example (fw A08, 40 s): 185 Mbps average, 3 % ping loss. SCell state 2 from 09:58:04 to 09:58:35 at 263-317 Mbps, traffic dips at 09:58:14 and 09:58:31, then state 1.
Observations with locks
Lock Result
AT+QNWLOCK=“common/5g”,523,156510,15,28 Prints +CGEV: ME DETACH when applied and when removed. PCell stable, 0 % loss, no 17 s events, but n78 SCell configured and never activated (state 1, RSRP -86..-92) even under 40 s load. 38-47 Mbps.
AT+QNWCFG=“nr5g_earfcn_lock”,1,156510:15 (hot, no detach, right after attach with SCell state 2) SCell goes to state 1 within seconds, never reactivated. Link stable, 39-50 Mbps, 0-0.7 % loss.
AT+QNWCFG=“nr5g_earfcn_lock”,2,156510:15:636576:30 (hot, SCell state 2) SCell stays active (265-302 Mbps), but PCell changes to n78 continue every 17 s and SCell deactivates after the second (155 Mbps avg, 6.5 % loss).
No effect on the pattern: nr5g_4mimo_enable 0, 3gpp_rel R16,R15, nr5g_cdrx 0, event_a3_offset 1,255, nr5g_band_priority 28, switching MBN profile (3 tried). AT+QNWCFG=? and AT+QCFG=? list no SRS or antenna-switching option. AT+QNVFR / AT+QNVFW are available.
Reference device (same cell, different SIM, same data plan, same operator)
ZTE MC8512 (MediaTek M80) holds n28 PCI 523 + n78 PCI 597 at 100 MHz for hours. It needed both:
  • (a) SRS Tx antenna switching disabled: AT+ESBP=5,“SBP_NR_SRS_TX_SWITCH”,0
  • (b) a PCell lock effective in connected mode: AT+EMMCHLCK=1,11,0,156510,523,3, applied after the SCell is already active; it does not detach and keeps the active SCell. Without them the ZTE showed the same handover to n78 PCI 597.
Dear @hernaj
=>No AT command or NV to disable SRS antenna switching capability.
=>AT+QNWLOCK=“common/5g” always forces a cell re-selection.
=>No ways to control.
=>Expected behavior. After PCI lock, the module will no longer measure inter-frequency points or report measurement reports.
=>Your devices is Mikrotik, it is beeter to contact them and ask to support this.
Thanks @silvia, the information is now clear
Follow-up
The remaining problem is two n28 cells on the same ARFCN (156510), PCI 677 and 523, 2-4 dB apart. Only 677 aggregates n78.
  1. Is there a PCI exclusion (bar list) for NR SA that keeps inter-frequency measurements, unlike QNWLOCK?
  2. What does AT+QNWCFG=“event_a3_offset”,1,255 change, only new connections or also active ones, and is it saved in NV?
  3. Is there firmware newer than RG520FEUEAR03A08M4GX_01.300.01.300?
