RG502Q-EU latest firmware
Hello, I would like to update our 5G Modules. Will you please send me the latest firmware revision for RG502Q-EU, please? Thank you!
What is your current firmware version?
The firmware version number is RG502QEUAAR12A03M4G, THANK YOU!
this is the latest firmware
Can you send me a copy, I hope to reset the module
dear please send me this fimrware version at mine gmail address hameedraza0159@gmail.com
mine module hase this version and bricked mine modem .
RG502Q-EU
Revision: RG502QEUAAR12A02M4G_OCPU_TL
You need to get the openCPU SDK from your purchase channel
dear i am user of this router how i can get its from other country come to me and i have no contact now with them please do something for me if you can i will update firmware myself via qfile if you don’t have frimware then just share me rawprograme.xm or patch.xml i will take backup from other router and can flash to my bricked router.
Where i find tha last firmware of module? My email is manos555555@gmail.com
Thank you for providing the firmware file for my Kestel-based 5G module.
Before I proceed with the update, I need to confirm something important for my usage in Greece.
Could you please let me know if this firmware package includes the MDN (Modem Data Network) files or the necessary configuration files required to make the module compatible with Greek network providers (e.g., Cosmote, Vodafone, WIND)?
If not, could you provide guidance on how to obtain or generate these files so that I can ensure proper connectivity with local carriers?
Best regards,
Manolis
pls run and check
please send me RG502QEUAAR12A01M4G_BL
last frimware
m.aseri19922@gmail.com
thank you
It might be a customized firmware version. If there are no abnormalities with your device at present, it is not recommended that you update the firmware version.
