Hi, I have router 5g Arcadyan AW1000 with modem Quectel RG500Q-EA.
I uploaded new firmware for this router with the qmi_wwan_q driver.
Unfortunately, after the quectel-cm -s internet command, the modem does not register on the network. In regular qmi mode, everything works fine.
[07-13_18:16:35:265] Find /sys/bus/usb/devices/4-1 idVendor=0x2c7c idProduct=0x800, bus=0x004, dev=0x003
[07-13_18:16:35:266] Auto find qmichannel = /dev/cdc-wdm0
[07-13_18:16:35:266] Auto find usbnet_adapter = wwan0
[07-13_18:16:35:266] netcard driver = qmi_wwan_q, driver version = V1.2.6
[07-13_18:16:35:266] qmap_mode = 1, qmap_version = 9, qmap_size = 31744, muxid = 0x81, qmap_netcard = wwan0_1
[07-13_18:16:35:266] Modem works in QMI mode
[07-13_18:16:35:270] cdc_wdm_fd = 7
[07-13_18:16:36:271] QmiWwanInit message timeout
[07-13_18:16:37:645] Get clientWDS = 14
[07-13_18:16:37:676] Get clientDMS = 1
[07-13_18:16:37:709] Get clientNAS = 4
[07-13_18:16:37:741] Get clientUIM = 1
[07-13_18:16:37:773] Get clientWDA = 1
[07-13_18:16:37:805] requestBaseBandVersion RG500QEAAAR13A01M4G
[07-13_18:16:37:836] qmap_settings.rx_urb_size = 31744
[07-13_18:16:37:837] qmap_settings.ul_data_aggregation_max_datagrams = 11
[07-13_18:16:37:837] qmap_settings.ul_data_aggregation_max_size = 4096
[07-13_18:16:37:837] qmap_settings.dl_minimum_padding = 0
[07-13_18:16:37:965] requestGetSIMStatus SIMStatus: SIM_READY
[07-13_18:16:38:029] requestGetProfile[pdp:1 index:1] ///0/IPV4V6
[07-13_18:16:38:029] requestSetProfile[pdp:1 index:1] internet///0/IPV4
[07-13_18:16:38:093] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[07-13_18:16:38:125] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[07-13_18:16:38:157] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[07-13_18:16:38:157] ip link set dev wwan0 down
[07-13_18:16:38:161] ip addr flush dev wwan0_1
[07-13_18:16:38:165] ip link set dev wwan0_1 down
[07-13_18:16:53:197] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[07-13_18:17:08:237] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[07-13_18:17:23:276] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Is there any solution to this problem?
