hi expert quectel
i had been working long time to solve EN-DC mode disable , but it dont work
RG500Q-EA
Revision: RG500QEAAAR11A07M4G_ACY
command AT
AT+QENDC
+QENDC: 0,0,0,0
any suggestion how to solve ?
hi expert quectel
RG500Q-EA
command AT
AT+QENDC
+QENDC: 0,0,0,0
Dear @AWuser
RG500QEAAAR11A07M4G_ACY is a customized firmware, it is recommended to contact your provider and check if they have any seeting.
any command can use to reset the module
can RG500QEAAAR11A07M4G_ACY flash with other firmware by UART ?
Dear @AWuser
I am not sure if the customized firmware had modified some feature, so I can’t share other firmware to you for upgrade.Thanks for your understanding.
For the ENDC, please check the combinations in your region. Then you can check wheter module support these.
