Hi Quectel support,
I am working on RG500q 5G module and WiFi FG50v module.
Currently, I can run WiFi and 5G Module and set parameters like change SSID & password or security type(Open/secured/ WPA/WPA2 etc, get ip address,get mac address, port range, Tx/Rx data rate, Max devices connect possible, keep alive time, Multiple Mode (AP/AP+STA/STA)
In during working I facing some issues. Issues listed below.
I can start Httpd server in Module. It work successfully, But the HTML page is open in MQTT Client.
(flow of the testing :- Start Module(RG500Q) → Active WiFi(FG50v) module → Laptop connect with WiFi Module → get request call in browser with Laptop’s IP) is not working.
(Attached Image 1 for Start server)
And Can you help for the How to server communicate with dynamic firmware of RG500Q module?
Is it possible with TCP/socket? if yes, Please share the documents for that.
