RG255C latest firmware request
HI guys,
is there a new firmware for the RG255C modules available? We are currently running the RG255CGLABR01403M4G firmware
Kind regards
Pascal
I would also like this latest RG255C firmware.
Is there a repo somewhere where I can check for updates, or do I have to always use the forum to find the latest FW?
Please provide your detailed firmware version
Result from running AT+QGMR:
RG255CGLABR01A02M4G_01.001.01.001
I got it in my email, thank you.
Now I am trying to use QFirehose to update the firmware, using a Raspberry Pi (ARM).
I compiled QFirehose_Linux_Android_V1.4.17, but it fails to flash the firmware.
I get the following (log attached):
error_log.txt (6.0 KB)
I was able to successfully flash using a windows box and QFlash 7.1. Thank you!
Hi! @herbert.pan-Q
I am running the RG255CGLABR01A04M4G_01.001.01.001, would it be possible to obtain the latest version?
Also, is MBIM supported with the latest version?
I have sent it to you,pls check,and I hope you can click the :yellow_heart: for me,thx
Hello @herbert.pan-Q. Could you also send me the latest firmware for RG255C? Thank you
Hi @herbert.pan-Q ,
Currently running RG255CGLABR01A01M4G_01.001.01.001 version, could you send me the latest firmware ?
Thanks !
I would also like the latest firmware for RG255C-GL, please. My module currently has:
and I am having some issues with getting the GPS coordinates and NMEA logs. Maybe it’s not related to the firmware version but just to rule it out.
I have sent it to you,pls check,and I hope you can click the :yellow_heart: for me,thx;and can you provide same log for GPS?
Hi Herbert! Can you send me the latest firmware for the RG255C-GL?
I have modem with RG255CGLABR01A01M4G firmware. To work with mikrotik I need A04 or higher. I need windows driver too. Herbert, can You send it to me?
