RG255C-GL-RRC_INACTIVE (inactiveState) not indicated in UE capability
We are using the RG255C-GL in a 5G SA RedCap and would like to clarify whether the module supports RC_INACTIVE.
Setup:
  • Module: Quectel RG255C-GL
  • Firmware: RG255CGLABR01A05M4G_A0.300.A0.300
Observation:
We captured the NGAP UERadioCapabilityInfoIndication messages for two separate registrations and decoded them with Wireshark. In both messages, the UE-NR-Capability is fully decoded: ccessStratumRelease = rel17, supportOfRedCap-r17 = supported, and the nonCriticalExtension chain is present from v1530 to v1700. However, the inactiveState field in UE-NR-Capability-v1530 is absent. TS 38.306 lists inactiveState as a per-UE capability with M = Yes.
Does the RG255C-GL support RRC_INACTIVE in 5G SA RedCap operation?
Dear @Jameel_Ali
Summary: Absence of inactiveState in UE-NR-Capability-v1530 is normal and spec-compliant
The inactiveState field in UE-NR-Capability-v1530 indicates whether the UE supports RRC_INACTIVE. In TS 38.306 (Table 4.2.x, General parameters), it is listed as a per-UE capability with M = Yes, which means RRC_INACTIVE is a mandatory feature since NR Release 15 — any UE declaring an access stratum release of Rel-15 or higher must implement it.
The key point is that “mandatory” applies to the feature, not to the presence of the capability field:
  • In the ASN.1 definition (TS 38.331), inactiveState is an OPTIONAL field (ENUMERATED {supported} OPTIONAL), so omitting it is a perfectly legal encoding.
  • Per TS 38.306, for mandatory features that still carry a capability parameter, the field does not signal “whether the feature is supported” — it signals “whether the feature has been successfully tested/validated”. Therefore, an absent field simply means the vendor did not declare the feature as validated; it does not mean the UE lacks RRC_INACTIVE support.
  • From a pure signaling-compliance standpoint, the network must still treat RRC_INACTIVE as supported and can configure suspend/resume and RNA procedures regardless of this field.
The only practical impact is in test/acceptance scenarios: some conformance tools or operator acceptance criteria use this field as a marker for “RRC_INACTIVE flow (suspend → paging → resume) has been validated.” If it is missing, such checks may be flagged as “not validated” — but the root cause to investigate would be actual implementation behavior, not the capability reporting itself.
Bottom line: An absent inactiveState is normal and spec-compliant. It means the feature is supported (mandatory) but not explicitly marked as tested/validated. Vendors only need to add the field when there is an explicit requirement to declare validation status.
Hi @silvia
Thanks for the explanation.
I agree that inactiveState is a mandatory feature with capability signalling (38.306 §4.2.2) and that the field reports “successfully tested” rather than “implemented”. However, 38.306 §4.1 also states that the network needs to respect the signalled UE capabilities, so a gNB is not required to configure RRC_INACTIVE for a UE that does not report it.
Lab result (Nokia gNB, Open5GS 2.7.6 with CoreNetworkAssistanceInformationForInactive in Initial Context Setup, actRrcInactState and actRrcInactStateRedCap enabled):
  • RM505Q (reports inactiveState=supported): suspended to RRC_INACTIVE, RAN paging + RRCResume works.
  • RG255C-GL FW RG255CGLABR01A05M4G_A0.300.A0.300 (no inactiveState): gNB sends UE Context Release Request (cause user-inactivity) and the UE goes to RRC_IDLE every time.
So in practice RRC_INACTIVE is unusable with RG255C on commercial gNBs that follow the signalled capability. Could you please confirm:
  1. Is RRC_INACTIVE (suspend/resume, RNA update, RAN paging) validated on RG255C-GL in any firmware? 2. Is there a firmware version, AT command or NV setting that makes the module report inactiveState in UE-NR-Capability-v1530?
I can provide the NGAP/RRC pcap if useful.
Dear @Jameel_Ali
I have sent AT commands to you via Message, please try again.
If still have issue, please help to capture log for confirm.
@silvia thanks in advance
Hello, @silvia
We have the same issue as in this thread with an RG255C-GL (Teltonika RUT271), firmware RG255CGLABR01A0XXXXX
In UE-NR-Capability the module sends accessStratumRelease rel17 and supportOfRedCap-r17 supported, and inactiveState is absent. On a Nokia gNB with RRC Inactive enabled, the gNB releases the UE context on inactivity and the UE goes to RRC Idle. A UE that sends inactiveState supported is suspended.
Please share the AT commands you sent to Jameel_Ali on 9 Nov, or the firmware that makes the RG255C-GL report inactiveState in UE-NR-Capability-v1530. I can provide the NGAP capture if needed.
Dear @e102_gamma
