I’m testing an RG255C-GL (p/n RG255CGL00AB-4M2-M20AA ) on a custom board. The WWAN side of things is working as expected, however I’m having some issues with the GNSS.
The module is connected to a GPS antenna (which we know works).
After turning on the GPS (AT+QGPS=1) NMEA0183 sentences are written on /dev/ttyUSB1 as expected, however, even after several tens of minutes, the GPS can’t get a fix.
Here is the configuration:
ATI
RG255C-GL
Revision: RG255CGLABR01A04M4G
AT+QGPSCFG="gpsnmeatype"
+QGPSCFG: "gpsnmeatype",31
AT+QGPSCFG="beidounmeatype"
+QGPSCFG: "beidounmeatype",1
AT+QGPSCFG="galileonmeatype"
+QGPSCFG: "galileonmeatype",31
AT+QGPSCFG="glonassnmeatype"
+QGPSCFG: "glonassnmeatype",4
AT+QGPSCFG="outport"
+QGPSCFG: "outport",usbnmea
My questions are:
Am I missing something?
Are there newer firmware/known bugs?
Is there a module-specific guide on how to use the GNSS?
Hello @herbert.pan-Q ,
Thank you very much for the documents. The hardware reference manual seems to be for a different form factor (LGA), while I have the m.2. Do you have the m.2 version?
I tried to enable everything following the GNSS documents, but still no fix. The parameters I set:
Dear @gab
From nmea sentences, it didn’t have any satellites was found, so it is hard to fix.
Please confirm your antenna meet requirement and connect correct port.
I sent the M2 HD document to you via Message, please check.
