Module: RG255C-GL
Firmware: RG255CGLABR01A04M4G_01.001.01.001
Network: 5G SA, band n28, NR-only (mode_pref = NR5G). Registration works reliably.
I am trying to configure idle-mode eDRX and PSM. What I observe:
AT+CEDRXS=?returns+CEDRXS: (0-3),(4,8),(0-15)AT+CEDRXS=2,8,"1111"→ERROR, although 8 is declared as supportedAT+CEDRXS=2,6,"1111"→ERRORAT+CEDRXS=2,4,"1111"→OK, but after re-registrationAT+CEDRXRDPalways returns+CEDRXRDP: 0and no+CEDRXPURC arrivesAT+CPSMS→ERRORin all forms, includingAT+CPSMS=?- Neither
+CEDRXSnor+CPSMSappears in the RG255C AT Commands Manual V1.1.2
My questions:
- Is idle-mode eDRX supported for NR SA on this module?
- If so, which
<AcT-type>should be used, and from which firmware version? - Why does
AT+CEDRXS=?declare type 8 if the set command rejects it? - Is PSM supported, under
+CPSMSor a vendor command?
