RG255C driver and quectel-cm tool that support the modem
Hi there,
I have been struggling to setup this specific modem (which is required by new customers) to work with my openwrt router. I have been using for our previous customers RM500Q modem with support for multiple PDN before using the qmi_wwan_q driver and the quectel-cm tools (quectel-qmi-proxy and other additional scripts to set it up). While googling around, I found only one post (which was stating it as a hack - which is to use mbim mode). Now, I am even wondering if the driver supports qmi mode and if I can even use the quectel-cm tools to manage the connectivity? Thank you and looking forward. For sending the drivers: my email is: ekathva.advaita in gmail.
Thank you.
Most Quectel modems should work with standard QMI and MBIM Linux drivers.
If you need help with configuration, I suggest asking a question in OpenWrt forum.
I am using the same configuration as I had been using in the previous configuration with another modem. And the post I was referring to: you have commented it :slight_smile: So, with the driver that I was provided previously, when I wrote the vendor product id in the new_id, I was getting the ttyUSB[0,1,2], but the /dev/cdc-wdm0 not being created. When I got the driver from the vendor who was supplying us with the modem, I managed to get the /dev/cdc-wdm0 device but not the ttyUSB*, which I fixed by adding hotplug to write that product vendor id. And for some reason, the quectel-CM was looking for wwan0 interface in the wrong directory, I fixed that one in quectel-CM and it is not still working. That is the reason, I am wondering if there is new driver and quectel-CM tools which is tested together. Thank you for the reply.
OpenWrt uses standard Linux drivers and does not use third party tools such as quectel-cm.
I have tried the standard qmi_wwan driver as well - that did not work (just like with the qmi_wwan_q which is being used with RM500Q, which I tried also with this modem). So, they don’t even create the /dev/cdc-wdm0 device with this modem. About quectel-cm, I don’t know how it was even acquired (I always thought that it is quectel provided - for some reason, it manages the connection - like using the proxy and setting up multiple PDN). I have no idea if I can do with what I get out of openwrt though! Do you have any specific documentation or example of that? Would be happy and thanful.
If you are using the official version of OpenWrt, and not something that is customized by the manufacturer, ask a question in the OpenWrt forum.
Does it mean that there is no solution of this issue in this forum? And there is nothing like a new qmi_wwan_q driver and quectel-cm tools?
@eku
Please try it.
qmi_wwan_q_0315 (1).tar.gz.zip (859.0 KB)
quectel-CM_0319 (1).tar.gz.zip (312.6 KB)
If there is still anything wrong, please provide the log.
Now it seems to work - although it is taking some time for quectel-qmi-proxy to come alive. But once that is up, I see it up and running. Thank you very much. Okay, after testing it a bit more, I see that it is not supporting the multiple PDN. Am I missing something? And I still need to do: echo “2c7c 0316” > /sys/bus/usb-serial/drivers/option1/new_id to get the ttyUSB* exposed, and setup 4 profiles like this:
chat -t5 '' AT OK < /dev/$tty > /dev/$tty
chat -t5 '' AT OK 'AT+CGDCONT=1,""' OK < /dev/$tty > /dev/$tty
chat -t5 '' AT OK 'AT+CGDCONT=2,""' OK < /dev/$tty > /dev/$tty
chat -t5 '' AT OK 'AT+CGDCONT=3,""' OK < /dev/$tty > /dev/$tty
chat -t5 '' AT OK 'AT+CGDCONT=4,""' OK < /dev/$tty > /dev/$tty
wwan0_1 is up and running, but the error given below belongs to wwan0_2.
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:133] Modem works in QMI mode
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:134] connect to quectel-qmi-proxy0 sockfd = 7
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:134] cdc_wdm_fd = 7
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:196] Get clientWDS = 9
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:231] Get clientDMS = 3
Mon Jun  3 05:40:06 2024 user.notice mwan3-hotplug[10004]: mwan3 hotplug on qmi not called because interface disabled
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:264] Get clientNAS = 4
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:299] Get clientUIM = 3
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:332] Get clientWDA = 2
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:366] requestBaseBandVersion RG255CGLABR01A02M4G
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:400] qmap_settings.rx_urb_size = 16384
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:400] qmap_settings.ul_data_aggregation_max_datagrams  = 11
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:400] qmap_settings.ul_data_aggregation_max_size       = 8192
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:400] qmap_settings.dl_minimum_padding                 = 0
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:536] requestGetSIMStatus SIMStatus: SIM_READY
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:571] requestRegistrationState2 MCC: 244, MNC: 5, PS: Attached, DataCap: LTE
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:604] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:604] ip addr flush dev wwan0_2
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:610] ip link set dev wwan0_2 down
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:638] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:638] call_end_reason is 1
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:638] call_end_reason_type is 2
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:638] call_end_reason_verbose is 236
Mon Jun  3 05:40:06 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:06:638] try to requestSetupDataCall 5 second later
Mon Jun  3 05:40:11 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:11:664] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jun  3 05:40:11 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:11:665] call_end_reason is 1
Mon Jun  3 05:40:11 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:11:665] call_end_reason_type is 2
Mon Jun  3 05:40:11 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:11:665] call_end_reason_verbose is 236
Mon Jun  3 05:40:11 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:11:665] try to requestSetupDataCall 10 second later
Mon Jun  3 05:40:21 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:21:687] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jun  3 05:40:21 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:21:687] call_end_reason is 1
Mon Jun  3 05:40:21 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:21:687] call_end_reason_type is 2
Mon Jun  3 05:40:21 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:21:687] call_end_reason_verbose is 236
Mon Jun  3 05:40:21 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:21:687] try to requestSetupDataCall 20 second later
Mon Jun  3 05:40:41 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:41:724] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jun  3 05:40:41 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:41:724] call_end_reason is 1
Mon Jun  3 05:40:41 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:41:725] call_end_reason_type is 2
Mon Jun  3 05:40:41 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:41:725] call_end_reason_verbose is 236
Mon Jun  3 05:40:41 2024 daemon.notice netifd: qmi (10019): [06-03_05:40:41:725] try to requestSetupDataCall 40 second later
It has nothing to with the option driver.
Please check the
AT+CGDCONT?
Thank you. Now it seems to be solved after I passed the different apn name in my chat command. That was in the hotplug, so, I never see any error and was thinking it was setting up the four profiles (which was not true). Now, I say - my problem is solved
Yes. The RG255C seems do not support the same APN.
Hi @eku, I am having the same problem as you and even after using the drivers that solved the issue for you, the device cdc-wdm0 is not coming up. Did you use any special option to compile/add the qmi_wwan_q driver to OpenWrt?
Ask at OpenWrt forum, I don’t think there is a need to compile any driver.
Hi @jfrog, from what I have experience, default drivers do not recognize the module. I have compiled the qmi_wwan_q driver using the OpenWrt SDK and add it to the image but still the cdc-wdm0 interface doesn’t show. Trying to use ECM gives an IP address but not connectivity, and trying to use mbim shows the wwan interface but neither quectel-CM nor modemmanager are able to communicate with the module effectively
