Response "AT+QGPSXTRATIME=?"
When using OneXtra of the BG96, I try to check the time with “AT+QGPSXTRATIME=?”. However instead of values, i get the actual desription of the values. Why aren’t I getting the values. I injected the time before this command.
Screenshot of reponse to “AT+QGPSXTRATIME=?”:
response_time_cmd
Kind regards,
Jeroen
Hi @JeroenS
You need check with AT+QGPSXTRATIME?, without equal charater.
I already tried that, but then I only get “0” (OK) and no values. However, I the document for GNSS AT commands realy states that “AT+QGPSXTRATIME=?” should be used:
@Linkin-Q is there a way to get value of injected xtra time?
Hi @AndreySV
This command should be OK.
