The modem enumerates only with one malformed USB interface (vendor class, no AT port) so I cannot issue AT commands. I have the firmware package you sent.
What is the exact EDL entry procedure for RM530N-GL (bcdDevice 0x0504)?
I have the M.2 card exposed on a Waveshare USB adapter. Please specify:
- Which PCB test points to short (with a photo if possible), OR
- The M.2 connector pin number to pull to 1.8V, OR
- A USB vendor command / QDownload tool that forces EDL
Also please confirm whether USB_BOOT is shorted to GND or pulled up to 1.8V on this board.
=========================== USB Port7 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 2-7
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
PortConnectorIsTypeC : no
ConnectionIndex : 0x07 (Port 7)
CompanionIndex : 0
CompanionHubSymLnk : USB#ROOT_HUB30#4&1d2d9bc&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 0x03 (Port 3)
→ CompanionPortChain : 2-3
========================== Summary =========================
Vendor ID : 0x2C7C (Anysmart Technologies Co., Ltd.)
Product ID : 0x0801
Serial : “F3BB729E”
USB Version : 2.1 (USB 3.x connected at HighSpeed - 480 Mbit/s)
Port maximum Speed : High-Speed (Companion Port 2-3 is doing the SuperSpeed)
Device maximum Speed : SuperSpeedPlus 10 GBit/s
Device Connection Speed : High-Speed
Self powered : no
Demanded Current : 500 mA
Device Manager Problem : 28 (CM_PROB_FAILED_INSTALL)
Used Endpoints : 1
======================== USB Device ========================
DriverKeyName : ERROR_FILE_NOT_FOUND
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : RM530N-GL
BusReported Device Desc : RM530N-GL
Kernel Name (PDO) : \Device\USBPDO-8
Device ID : USB\VID_2C7C&PID_0801\F3BB729E
Hardware IDs : USB\VID_2C7C&PID_0801&REV_0504 USB\VID_2C7C&PID_0801
Driver KeyName : -
Legacy BusType : PNPBus
Class : -
Class GUID : -
Service : -
Enumerator : USB
Location Info : Port_#0007.Hub_#0002
Address : 7
Location IDs : PCIROOT(0)#PCI(0500)#USBROOT(0)#USB(7), ACPI(SB)#ACPI(PCI0)#PCI(0500)#USBROOT(0)#USB(7)
Container ID : {eab6c4fb-7c30-5a58-bdce-d823676c8c91}
Manufacturer Info : -
Capabilities : 0x14 (Removable, UniqueID)
Status : 0x01806400 (DN_HAS_PROBLEM, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 28 (CM_PROB_FAILED_INSTALL)
First Install Date : 2026-03-15 09:50:03
Last Arrival Date : 2026-04-16 11:39:07
EnhancedPowerMgmtEnabled : 0
Power State : D3 (supported: D0, D3, wake from D0)
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\2C7C08010504
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x07 (Port 7)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x00 (Configuration 0)
Device Address : 0x01 (1)
Is Hub : 0x00 (no)
Device Bus Speed : 0x02 (High-Speed)
Number of open Pipes : 0x00 (0 pipes to data endpoints)
--------------- Connection Information V2 -------------
Connection Index : 0x07 (7)
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes, port supports USB 1.1)
Usb200 : 1 (yes, port supports USB 2.0)
Usb300 : 0 (no, port not supports USB 3.0) → but Companion Port 2-3 does
ReservedMBZ : 0x00
Flags : 0x0A
DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 1 (Device is SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 1 (Device is SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x210 (USB Version 2.1)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x40 (64 bytes)
idVendor : 0x2C7C (Anysmart Technologies Co., Ltd.)
idProduct : 0x0801
bcdDevice : 0x0504
iManufacturer : 0x01 (String Descriptor 1)
iProduct : 0x02 (String Descriptor 2)
iSerialNumber : 0x03 (String Descriptor 3)
bNumConfigurations : 0x01 (1 Configuration)
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x003A (58 bytes)
bNumInterfaces : 0x01 (1 Interface)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x04 (String Descriptor 4)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0xFA (500 mA)
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x01 (Interface 1) *!*ERROR must be < bNumInterfaces (1)
bAlternateSetting : 0x00
bNumEndpoints : 0x03 (3 Endpoints)
bInterfaceClass : 0xFF (Vendor Specific)
bInterfaceSubClass : 0x00
bInterfaceProtocol : 0x40
iInterface : 0x00 (No String Descriptor)
----------------- Unknown Descriptor ------------------
bLength : 0x05 (5 bytes)
bDescriptorType : 0x24
Data (HexDump) : 05 24 00 10 01
Data (HexDump) : 05 24 01 00 00
bLength : 0x04 (4 bytes)
Data (HexDump) : 04 24 02 02
Data (HexDump) : 05 24 06 00 00
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x82 (Direction=IN EndpointID=2)
bmAttributes : 0x03 (TransferType=Interrupt)
wMaxPacketSize : 0x000A
Bits 15..13 : 0x00 (reserved, must be zero)
Bits 12..11 : 0x00 (0 additional transactions per microframe → allows 1..1024 bytes per packet)
Bits 10..0 : 0x0A (10 bytes per packet)
bInterval : 0x09 (256 microframes → 32 ms)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0200 (max 512 bytes)
bInterval : 0x00 (never NAKs)
bEndpointAddress : 0x01 (Direction=OUT EndpointID=1)
----------------- Device Qualifier Descriptor -----------------
Error : ERROR_GEN_FAILURE (because the device has problem code CM_PROB_FAILED_INSTALL)
---------- Binary Object Store (BOS) Descriptor -----------
bDescriptorType : 0x0F (Binary Object Store)
wTotalLength : 0x002A (42 bytes)
bNumDeviceCaps : 0x03
------------- USB 2.0 Extension Descriptor ------------
bDescriptorType : 0x10 (Device Capability Descriptor)
bDevCapabilityType : 0x02 (USB 2.0 Extension)
bmAttributes : 0x10E
LPMCapable : 1 (Link Power Management protocol is supported)
BESLAndAlternateHIRD : 1 (BESL & Alternate HIRD definitions are supported)
BaselineBESLValid : 1 (valid)
DeepBESLValid : 0 (not valid)
BaselineBESL : 1 (150 µs)
DeepBESL : 0
----- SuperSpeed USB Device Capability Descriptor -----
bLength : 0x0A (10 bytes)
bDevCapabilityType : 0x03 (SuperSpeed USB Device Capability)
bmAttributes : 0x00
Bit 0 Reserved : 0x00
Bit 1 LTM Capable : 0x00 (no)
Bit 7:2 Reserved : 0x00
wSpeedsSupported : 0x0F (Low-Speed, Full-Speed, High-Speed, SuperSpeed)
bFunctionalitySupport : 0x01 (lowest speed with all the functionality is ‘Full-Speed’)
bU1DevExitLat : 0x00 (0 µs)
wU2DevExitLat : 0x0000 (0 µs)
--------- SuperSpeedPlus USB Device Capability --------
bLength : 0x14 (20 bytes)
bDevCapabilityType : 0x0A (SUPERSPEED_PLUS)
bReserved : 0x00
bmAttributes : 0x00000001
Bit 4:0 SSAC : 0x01 (2 Sublink Speed Attributes)
Bit 8:5 SSIC : 0x00 (1 Sublink Speed ID)
wFunctionalitySupport : 0x1100
Bit 3:0 SSID : 0x00 (0)
Bit 7:4 Reserved : 0x00 (0)
Bit 11:8 Min Rx Lanes : 0x01 (1)
Bit 15:12 Min Tx Lanes : 0x01 (1)
wReserved : 0x00
bmSublinkSpeedAttr0 : 0x000A4030
Bit 3:0 SSID : 0x00 (Sublink Speed Attribute ID 0)
Bit 5:4 LSE : 0x03 (Lane Speed Exponent is 9 → Gbit/s)
Bit 7:6 ST : 0x00 (Symmetric, Receive Mode)
Bit 13:8 Reserved : 0x00
Bit 15:14 LP : 0x01 (SuperSpeedPlus)
Bit 31:16 LSM : 0x000A (Lane Speed Mantissa is 10)
bmSublinkSpeedAttr1 : 0x000A40B0
Bit 7:6 ST : 0x02 (Symmetric, Transmit Mode)
→ max Rx Speed : 10 Gbit/s
→ max Tx Speed : 10 Gbit/s
Port Chain : 2-7
Properties : 0x01
CompanionIndex : 0
-> CompanionPortChain : 2-3
Product ID : 0x0801
Serial : "F3BB729E"
Self powered : no
Used Endpoints : 1
Driver KeyName : -
Class : -
Class GUID : -
Service : -
Enumerator : USB
Address : 7
Location IDs : PCIROOT(0)#PCI(0500)#USBROOT(0)#USB(7), ACPI(_SB_)#ACPI(PCI0)#PCI(0500)#USBROOT(0)#USB(7)
Is Hub : 0x00 (no)
Usb300 : 0 (no, port not supports USB 3.0) -> but Companion Port 2-3 does
ReservedMBZ : 0x00
Flags : 0x0A
ReservedMBZ : 0x00
idProduct : 0x0801
bcdDevice : 0x0504
bmAttributes : 0x80
Bits 12..11 : 0x00 (0 additional transactions per microframe -> allows 1..1024 bytes per packet)
bInterval : 0x09 (256 microframes -> 32 ms)
DeepBESL : 0
bmAttributes : 0x00
bFunctionalitySupport : 0x01 (lowest speed with all the functionality is 'Full-Speed')
bReserved : 0x00
wReserved : 0x00
Bit 5:4 LSE : 0x03 (Lane Speed Exponent is 9 -> Gbit/s)
-> max Rx Speed : 10 Gbit/s
-> max Tx Speed : 10 Gbit/s
-------------------- String Descriptors -------------------
String descriptors are not available (because the device has problem code CM_PROB_FAILED_INSTALL)
