Hello there. Could I get the latest firmware version sent to me for the RM530N-GL module? I’ve tried to email but haven’t heard anything.
Thanks!
Thanks!
Hi,@iamromulan
Could you tell me the current firmware version of yours?
RM530NGLAAR05A01M4G_01.200.01.200
Even if it is the current version could I get a copy? I need to flash fresh ![]()
Hi,@iamromulan
Certainly. This is the latest firmware version.I’ve already sent it to you via email.pls check.
(post deleted by author)
accidentally deleted my request…
Greetings, my version is as follow:
firmware revision: RM530NGLAAR03A02M4G
can I also have the latest version please? What’s the procedure to update the FW.
On a separate note. Are there any prefered/desired extra parameters for linux to improve performance/throughput of the connection specific to Quectel devices?
Dear @rhqq
Why did you want to upgrade? Is there any issue?
For this module, it has R05 baseline, do you want to upgrade?
no issues, I think, I just wanted to make sure that I’m running latest FW given it’s a relatively recent device.
the only issue I’m running into is that passing traffic over modem interface causes 4-5 times more software interrupts than similar volume of traffic over regular ethernet - is this something to be expected? are there any tunables in linux kernel/modules to maximize the throughput?
I know for a fact that modem is capable of maximizing BTS (~2.5Gbit) when connected to a high performance device (7840HS), but struggling on J4115 - because it maxes out on SIs, giving around 800-900MBit max. at the same time I am able to do similar volumes of traffic (nat/routing) via ethernet.
Dear @rhqq
For throughput, module don’t have way to modify.
would you be able to provide the latest version of the firmware to me for the 530n-gl? thanks!
Hi Sir,
What is your current firmware version? you may try via ATI command to check.
i ended up buygin a r520m-gl. looking for firmware for this, and also, my eithernet enclosure won’t recognize my sim, i tried another enclosure fwiw
Hi Sir
About the new module, what is the current firmware version? Much appreciation.
latest firmware. please
RM530NGLAAR05A01M4G
Dear silvia, I use RM530 N-GL
The current firmware version is
Want the latest firmware and the latest available AT command documentation
RM530NGLAAR05A01M4G_01.201.01.201
Because I am using this hardware in CPE equipment, I heard that the firmware version distinguishes between the high-power PC1.5 specification of 29dBm and the normal power PC2 specification of 26dBm or PC3. Since 29dBm is about twice the transmission power of 26dBm, there is a huge speed difference between the two,
If there is a high-power firmware version, can you send me a high-power firmware version? If you don’t have it, send the default latest firmware
thank you
RM530NGLAAR05A01M4G_01.200.01.200. could you please send me a link to this firmware.
Hi, I have RM530NGLAAR05A01M4G_01.200.01.200 installed and I need an updated firmware with band locking and CA support (preferably RM530NGLAAR01A04_OPENRU or 01.201.01.201). Can you share the link or send to email fix3000@gmail.com
Dear @fix_fix
Hi I would like to have the latest firmware as well.
My current firmware revision: RM530NGLAAR03A02M4G
Thanks in advance
