I am performing a custom hardware bring-up and testing QuecPython. Could you please provide the matching QuecPython OpenCPU firmware package and release tools for my module?
Could you please provide download links for the following resources:
The matching QuecPython OpenCPU firmware package (.pac file) compatible with this hardware tier.
The exact factory AT-command firmware recovery image (EG915NEUAPR03A03M16_01.200.01.200) or the latest verified updated version that is compatible for a safe rollback.
The recommended flashing tools (UpgradeDownload / QFlash) and Windows or Linux USB drivers to manage the download sequence.
Can you please help me to find the matching QuecPython firmware for the EG915NEUAP version? on the downloads section, I only see following firmware versions for EG915N.
QPY_OCPU_EG915N_LAAK_FW
QPY_OCPU_EG915N_EAAK_FW
QPY_OCPU_V0001_EG915N_EAAC_FW
Appreciate if you could support me to find QuecPython firmware and AT-command firmware recovery image.
Thanks.
The module version I have is EG915N-EUAP and the as I checked, the firmware on download section seems to be for EG915N-LAAK, EG915N-EAAK and EG915N-EAAC. If one of they are compatible with the EG915N-EUAP module version, can you please mention which one should I try?
Hi @Felix.feng-Q, I’m in the same situation: custom hardware based on EG915NEUAP-N06-SGNSA, planning QuecPython for production. Could you please answer point by point:
Could you send me the matching QuecPython firmware for EUAP (and tell me which factory AT base version it matches)? Will it be published on the official download page?
Is the internal GNSS usable under QuecPython on this build? The quecgnss docs don’t list EG915N which API/interface should we use, and are there GNSS/LTE concurrency limits?
Does the EUAP build keep the same GPIO/PWM/ADC/I2C map as the EUAG documentation, and is pm.autosleep() supported?
What is the official channel to obtain this firmware for mass production, and is OTA upgrade supported?
Points 1–2 are blocking our production order written confirmation would be much appreciated. Thanks!
