Request: Quectel_Linux_PCIE_MHI_Driver for RM520N-GL (ARM64, kernel 5.15-tegra)
I am using RM520N-GL on NVIDIA Jetson AGX Orin (ARM64, kernel 5.15.148-tegra, Ubuntu 22.04).
PCIe link is up and the device is visible in lspci:
0005:01:00.0 Unassigned class [ff00]: Qualcomm Device 0308
I tried using the mainline mhi_pci_generic driver but it fails with:
“failed to power up MHI controller, error -110”
Could you please share the latest Quectel_Linux_PCIE_MHI_Driver (V1.3.8 or newer) for RM520N-GL?
Thank you.
Dear @Kyuyong_Park
Hi Silvia,
Thank you for sending the driver package. I will test it and update here.
By the way, could you also share the latest Quectel_QConnectManager for PCIe use? I found that the open-source version (V1.6.7) does not seem to support PCIe QMI/MBIM mode fully — it only handles ECM/RNDIS/NCM. A version that works with pcie_mhi and rmnet_mhi0 would be very helpful.
Thank you again!
Dear @Kyuyong_Park
I have sent a newer version to you via Message, please check.
Hi @silvia
We would like to request the Quectel_Linux_PCIE_MHI_Driver, Android_QMI_WWAN_Driver and Quectel_QConnectManager files.
Kernel Linux 5.15.186
Thank you!
V.C
Dear @Vincent_Cheung
