Request: Official RM520N‑GL A04 Ethernet Firmware (RM520NGLAAR03A04M4G_01.202.xx / 01.204.xx)
Hello Quectel Support Team,
I would like to request the official Ethernet‑enabled A04 firmware package for the RM520N‑GL module.
My current firmware version:
Code RM520NGLAAR03A04M4G_01.204.01.204
My hardware setup:
  • RM520N‑GL module
  • PCIe → Ethernet adapter
  • Ethernet interface detected, link is up
    Able to ping 192.168.225.1
Reason for request:
My current firmware appears to include only partial Ethernet support (driver loads successfully), but the following AT commands return ERROR:
Code
AT+QETH?
AT+QETH="eth_mode","router"
AT+QETH="dhcp","enable"
AT+QETH="route","enable
However, these commands should be available in the full A04 Ethernet firmware
What I need:
Please provide the full official A04 Ethernet firmware package, including:
contents.xml
prog_firehose_ddr.elf
rawprogram0.xml
patch0.xml
All required partition images
I need the version that includes:
Full QETH subsystem
Ethernet routing
DHCP server
NAT
QMAP-over-Ethernet
PCIe Ethernet mode support
Purpose:
I am testing RM520N‑GL in PCIe Ethernet mode and need the complete Ethernet feature set for proper WAN operation.
Thank you very much for your assistance.
Please let me know if you need my module SN, MEID, or any additional information.
Best regards,
Dear @Kambo
I have sent the latest firmware to you.
What is the type of your ethernet? Is it RTL8125?
If yes, please follow the steps to try in this topic.
Modem Quectel RM520N-GL: Ethernet PDU support with WaveShare 5G M.2 TO Gigabit ETH support - IoT Modules / 5G Module - Quectel Forums
thank you
my ethernet chip is RTL8125bg, i am trying to make the modem work in standalone mode like a router ,to make the connection work with any device that have ethernet withoand the same time fix the TTL =64
i will follow the steps and get back with you
best regard
jean
Hi Silvia,
Would you please send me the same firmware ?
Thank you
