Request: Latest LC29H(DA) firmware
Hello
Problem: NR11A03S ignores RTCM with L1/L5 antenna
Module: LC29H(DA), $PQTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31, rover mode (PQTMCFGRCVRMODE = 1).
With an L1-only antenna, RTCM3 MSM7 from IBGE RBMC-IP (mountpoint SPC10: 1006, 1077/1087/1097/1127, 3 km baseline) achieves RTK Fixed in about 40 s. After switching to an L1/L5 antenna (GPS L5, Galileo E5a and BeiDou B2a now tracked), the module never applies the same stream. I verified it is 100% CRC-valid and the module answers commands on the same UART. GGA quality stays 1 and the differential age field stays empty.
Please may you send the latest LC29H(DA) firmware (NR11A04S or newer) and the flashing procedure. Also a Linux flashing tool would be welcome if one exists.
My email is: lfgomez@gmail.com
Thank you!
Hi @lfgomez I have sent the FW version to your email. Please do let me know if you have received the FW package. Best regards.
Dear Quectel Support Team,
I am using a Quectel LC29H-DA GNSS module with the following firmware:
  • Firmware version: LC29HDANR11A03S_RSA
  • Firmware date: 2024/03/19
  • Interface: UART, 115200 baud
Problem:
The module consistently reaches only RTK FLOAT, but never achieves RTK FIX, even when tested outdoors with a clear view of the sky.
My observations:
  • 22–25 satellites are reported.
  • The NTRIP connection is established successfully.
  • RTCM correction data is received and forwarded to the GNSS module.
  • Valid GNSS position data is available.
  • However, the RTK solution remains permanently in FLOAT mode.
I would appreciate your assistance with the following questions:
  1. Is firmware LC29HDANR11A03S_RSA dated 19 March 2024 the latest recommended firmware for the LC29H-DA?
  2. Is there a newer firmware version available?
  3. Are there any known issues with achieving RTK FIX using this firmware?
I would like to identify the root cause before changing the firmware or configuration.
Thank you for your support.
Kind regards
Hi @karl_123,
Please check your email, I have sent you the latest firmware with upgrade guide and documentation that could be helpful. Make sure to use latest firmware.
Regarding your issue please clarify and provide the following:
  1. Are you testing on the Quectel EVB or on your own PCB?
  2. What is your correction source? Please give the mountpoint name, the RTCM message types it provides, and the distance to the reference station.
    Note that LC29H (DA) accepts 1005/1006 and MSM4/5/7 messages, and the baseline should not exceed 15 km. Please also confirm the service’s constellations and frequency bands match the module’s.
  3. What C/N0 levels do you see (GSV), and how many satellites are actually used (GSA)? Which antenna are you using, and is it dual-band and under open sky?
  4. Is the correction stream arriving continuously at 1 Hz without gaps? Please check the differential age in the GGA sentence.
  5. Could you send logs covering several minutes of the FLOAT state: a regular NMEA+PQTM log and the NTRIP log? You reply on email I have sent you.
Best regards, Dobrica
Dear Support Team,
Thank you for sending me the latest firmware, upgrade guide, and documentation.
I am testing the LC29H-DA on my own PCB, not on the Quectel EVB.
After updating to the latest firmware, I noticed a significant improvement:
  • Before the update, I typically received around 20–25 satellites.
  • After the update, I receive around 25–35 satellites even more.
  • I can now achieve an RTK fix within approximately 3 minutes, even under suitable conditions.
I am using SAPOS Bayern as my correction service with the following mountpoints:
  • VRS_3_4G_BY - BEIDOU, GPS, GLONASS, RTCM 3 MSM, VRS
  • VRS_3_3G_BY - GPS, GLONASS, RTCM 3 MSM, VRS
I initially tested both mountpoints before updating the firmware, but I could only achieve RTK FLOAT.
After the firmware update, VRS_3_4G_BY still remains in FLOAT mode. However, when switching to VRS_3_3G_BY, I can now achieve a stable RTK FIX with excellent performance.
I am very satisfied with the current results using VRS_3_3G_BY.
It seems that the latest firmware has significantly improved the receiver’s performance. Im not sure maybe something wrong on BEIDOU Korrektion but its okay. Everything working.
Thank you again for your support and for providing the updated firmware.
Best regards
Karl
