Modem Type: Orca_NR_modem
Modem Software Version: MOCORTM_21A_W23.21.2_P6_Debug
Modem Hardware Version: udx710_modem
Thank you.
Thank you.
hello ,do you need Quectel latest firmware? May we know your module type?
Yes, I do need. How do I check for the module type?
you can use AT command to check your current firmware version
Okay. This is the output:
hello,from your feedback, it seems that it’s not the Quectel’s module firmware version. If you are using a terminal device, we recommend you contact the manufacturer for better support. Thank you~
I found this on the hardware module:
RG500L-EU
hello," MOCORTM_21A_W23.21.2_P6_Debug" this is the terminal device version number, to better support your query, we recommend you can contact the device vendor instead, they may provide a more suitable solution.many thanks~
