Is it possible to get the latest software for LC29HEA? I want to do update.
Thank you in advance for your help.
Hi Customer
Please use “$PQTMVERNO*58\r\n” to query the software version number and send the returned message to me.
Hi I guess I have the same module and I experience several issues. The most serious is that it reboots everytime I try the following:
$PQTMCFGSVIN,W,2,0,0,3106586.3552,1012454.4373,5459350.8736*04
Then it dumps:
$PQTMCFGSVIN,OK70
$GNGGA,172835.000,5916.130263,N,01803.067819,E,1,14,1.02,48.5,M,23.3,M,40
$GNRMC,172835.000,A,5916.130263,N,01803.067819,E,0.069,028.45,310524,A,V30
$GNGLL,5916.130263,N,01803.067819,E,172835.000,A,A48
$PAIR�
F1: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
U0: 0000 0001 [0000]
T0: 0000 00B2
Leaving the BROM
bootloader start!
bl_uart_init
hal_clock_set_pll_dcm_init
hal_emi_configure
rising freq to 384m level pass!
hal_flash_init
hf_fsys_ck freq=383821
hf_fsfc_ck freq=95762
bl_fota_process
info_type:0x1, record_data:0x400ffe0, record_len:2
info_type:0x1, info->is_init:0
Found, partition_type:10
fota_multi_info_start_addr_get() info_type:1 addr:0x26f000 storage_type:0
fota_multi_info_start_addr_get() info_type:2 addr:0x26f100 storage_type:0
info_type:0x1 start_addr:0x26f000 last_record_addr:0x26f000 data_num:0 history_record_count:0
ret:0, record_data:0xff 0xff
FOTA state: 0x1
info_type:0x2, record_data:0x400ffb4, record_len:2
info_type:0x2, info->is_init:0
fota_multi_info_start_addr_get() info_type:4 addr:0x26f180 storage_type:0
info_type:0x2 start_addr:0x26f100 last_record_addr:0x26f100 data_num:0 history_record_count:0
upgrade_flag :0
Partition(0) 0x8013000
Jump to addr 0x8013000
$PAIR001,002,138
$PAIR001,021,038
$PAIR021,AG3335A_V2.5.0.AG3335.QT_V2_20230116,D,N,520c828,2211151447,52f74c1,2211151447,ba1f2bb,2211151447,-13.58,-13.58,-11.50,-13.58,0,1,##,0,011
$PAIR011,00127
$PAIR010,1,-116
$PAIR010,2,-115
$PAIR001,002,039
$PAIR001,021,038
$PAIR021,AG3335A_V2.5.0.AG3335.QT_V2_20230116,D,N,520c828,2211151447,52f74c1,2211151447,ba1f2bb,2211151447,-13.58,-13.58,-11.50,-13.58,0,1,#P,0,062
$PAIR001,050,03E
$1,20381121,3072,1,7,126
$PQTMIMUTYPE,1,151
$PAIR001,106,13D
$PAIR001,107,03D
$PAIR107,020
$PAIR001,534,039
$PAIR001,124,03C
$PAIR001,106,03C
$PQTMVERNO*58
gives me:
$PQTMVERNO,LC29HBANR11A01S_CSA4,2023/01/16,18:20:07*07
Thank you for your help.
Ciao Michele, better to create a new topic:
your module is LC29HBA let you get a firmware even if the same ,it is a way to regenerate the partitions and restore the default settings…
Here the latest manuals
https://forums.quectel.com/uploads/short-url/gJTnPOK8MkEJIgLFR7QgjvrpUey.pdf
https://forums.quectel.com/uploads/short-url/ncdKSn5cRYyDbOpfYmvGGs1vEIA.pdf
