Dear Quectel Technical Support Team,
I am an individual user from India. I am not working for any company and I am not using the module for any commercial or corporate purpose.
I recently obtained a Quectel RG520F-JO 5G module from a scrap/second-hand circuit board. I do not have any information about its previous device, owner, application, carrier, or original firmware configuration.
I am trying to reuse this module for personal use, but I am experiencing several problems:
- Many SIM cards do not work with the module.
- The SIM cards that do work have an unstable Internet connection.
- The Internet connection frequently drops or becomes unstable.
- The module sometimes gets stuck in a boot loop and repeatedly restarts.
Because the module came from a scrap board, I suspect that the installed firmware may be customized for the original device/operator, outdated, corrupted, or otherwise unsuitable for normal use.
I found the following Quectel Forum discussion regarding the same RG520F-JO and the generic firmware:
In this discussion, I noticed that
RG520FJOAAR05A04M4G was provided/recommended as the generic firmware for RG520F-JO.
Could you please confirm whether RG520FJOAAR05A04M4G is compatible with my RG520F-JO and, if so, provide me with:
- The firmware package.
- The officially recommended QFlash tool.
- The required USB drivers.
- The correct flashing procedure/instructions.
- Any precautions or backup procedure I should follow before flashing.
I do not want to flash an incorrect firmware intended for another RG520F variant, because I understand that this could potentially make the module unusable.
I also have a Quectel UN65A module obtained from another scrap circuit board. I would appreciate it if you could also help me identify the correct standard/generic firmware for the UN65A and provide the appropriate flashing procedure for that module.
I have attached photographs of both modules and their circuit boards to this email.
For privacy and security reasons, I have covered/blurred the IMEI numbers and QR codes in the photographs. If you require the IMEI or other identification information to verify the exact hardware/firmware variant, I can provide it privately.
My goal is simply to repair and reuse these modules for personal use in India.
I would be very grateful for your technical guidance and for the correct firmware required to make these modules stable and usable again.
Thank you very much for your assistance.
Best regards,
Prakash solanki, India
