Request for prog_emmc_firehose.mbn for SC20-E Module
Hello Quectel Team,
I am using the SC20-E module and need to reflash some units due to a system issue. To proceed with recovery via QFIL, I am looking for the compatible prog_emmc_firehose.mbn file for the SC20-E.
Could someone from the support team please provide this file or guide me on how to obtain it?
Thank you for your help.
Best regards,
Amine
Instal.atlantic@gmail.com
Dear, customer:
Please provide the full OC number of your module and which Android version is used?
Thanks.
Thank you for the information.
We’ve noted the OC number: SC20ESA-8GB-STD and Android version: 8.1.0.
Best regards,
The email is sent, please download the package from the link.
Thanks.
Hello Quectel Team,
Thank you for providing the firmware for the SC20-E module.
Unfortunately, I tried flashing it on my device (model Q1-A6605), but it did not work. The flashing process fails — I believe the firmware version may not match the exact variant of my hardware.
I’m using QFIL via USB (EDL mode / HS-USB QDLoader 9008 is recognized).
The error occurs during the firehose stage or initialization.
To help you identify the correct version, I’ve attached photos showing the device details and flashing errors.
Could you please verify the compatibility and share the correct firmware package for this model?
SC20ASAR06A07_BP31.008_Android8.1.0.31.007_update
this showed in my device: BP01.010(SC20ESAR06A10)
Thanks again for your help and support.
Best regards,
Amine
The latest version is SC20ESAR06A10_BP10.011_Android8.1.0.01.009.
If you encounter burning issue, please check your environment.
From the image your provide, the version is already R06A10.
Thanks.
Thank you for your reply.
Yes, my device already has version R06A10, but the firmware you provided seems to be an older release or incomplete. I would like to kindly request the full and latest firmware version you mentioned:
Could you please provide the complete package (including firehose and all QFIL files) for this version so I can test it?
Thanks again for your support.
Best regards,
Amine
The link is sent again.
