Request for Official AT Command Manual & Band Lock Commands for RM551E-GL
Hello Quectel Support,
I currently have two RM551E-GL modems in use, each running different firmware versions:
One on RM551EGLAAR01A02M4G
One on RM551EGLAAR01A03M8G
I am requesting the official AT command manual (or PDF documentation) specific to the RM551E-GL, especially covering:
Band locking for LTE and NR5G
Aggregation control
RF configuration and custom lock logic
QCAINFO or other band reporting formats
Although I have been experimenting with commands like AT+QNWPREFCFG and AT+QCAINFO, I would like to follow officially documented procedures to avoid unintended modem behavior, especially under different firmware versions.
Could you please share:
  1. The latest AT command reference manual for RM551E-GL
  2. A guide or command set for band locking (LTE + NR5G) that is confirmed to work on firmware versions A02M4G and A03M8G
  3. Any known limitations or behavioral differences between the two firmware versions regarding band locking or QMI/MBIM interface support
Thank you in advance for your help!
