manufacturer used some codes not modules sleep after an hour or so. will try to reload driver. pls send as message today
It’s really important for me. can you help please
Hi
===》manufacturer used some codes not modules sleep after an hour or so. will try to reload driver. pls send as message today
Sorry, I don’t quite understand the problem you are facing. Do you need the M26FAR03A06 version to help you re-burn the firmware?
manufacturer used following codes and some others I dont know. now modules keeps disconnecting
AT+QSIMDET=0,0,0;&W AT+QSIMVOL=2&W
need to make back to factory settings. how do i do that. Also why firmware is not on company website and people have to beg for it?
Hi
You can use the AT&F command to restore factory Settings, but this only controls some parameters, you can try it
===>Also why firmware is not on company website and people have to beg for it?
Because we need to control the firmware version, for example: if the customer does not update the firmware standard, it will affect the field use.
I have already tried AT&F on ports
it didnt help the issue
isnt there like a driver or flash that makes the ports to factory setting.
I need this flash files ? anyone from support?
can you help? I need this flash files
Still waiting for reply
hello, any progress?
