Hello Quectel Support team,
Could you please send me the latest Standard AT firmware package (.bin) for the FCM360W module (specifically for the FCM360WAAR01 branch)?
Currently, my module is running on FCM360WAAR01A04 and I am facing a corrupted UFS File System issue (failing to write/upload TLS certificates). I would like to upgrade to the latest version to resolve this.
Thank you in advance for your support!
Hi Geboul,
I will send you the latest AT firmware along with the flashing tools. Can you also show how is the UFS File system is corrupted?
For the command for file upload, you may refer: FCM360W: File System Issue – AT+QFWRITE returns +QFWRITE: 0,0 - IoT Modules / WIFI/BT Module - Quectel Forums
Please also run the commands below and send me the URC and debug logs (copy from your serial terminal, it will be collected through the UART 0 and UART 2, you may need TTL board for this depends on your board final design):
AT+QVERSIONAT+QFLDS?AT+QFLSTAT+QFOPEN?(if any handle is open, runAT+QFCLOSE=<handle>on it and note the response)AT+QRST, then repeat steps 2 and 3- Write test:
AT+QFOPEN="test.txt",1
AT+QFWRITE=<handle>,100(then send exactly 100 bytes)
AT+QFCLOSE=<handle> AT+QFLDS?,AT+QFLST,AT+QFDEL="test.txt",AT+QFLDS?- Repeat the certificate write:
AT+QFOPEN="ca.pem"
AT+QFWRITE=<handle>,<size>
AT+QFCLOSE=<handle>
Please tell me which step fails and the exact error.
