We are using your 7Semi Industrial LC29H Series Dual-Band GNSS RTK Modem based on the Quectel LC29HBA module.
Module Details:
Product: 7Semi Industrial LC29H Series Dual-Band GNSS RTK Modem
GNSS Module: Quectel LC29HBA
Firmware Version: LC29HBANR11A02S_CSA2
Build Date: 2023/05/09
Software Tool: QGNSS V2.4
We are trying to configure the module according to the LC29H & LC79H GNSS Protocol Specification V1.5 (Released: 2025-09-12), but we are facing several issues.
1. NMEA Message Configuration
We want to configure the receiver to output only the GGA and RMC NMEA sentences.
When executing:
$PQTMCFGMSGRATE,W,GGA,1
or
$PQTMCFGMSGRATE,R,GGA
the module responds with:
$PQTMCFGMSGRATE,ERROR,1
According to the protocol specification, Error Code 1 = Invalid parameters.
2. Constellation Configuration
We also attempted to enable NavIC using:
$PQTMCFGCNST,W,1,1,1,1,1,1
and query the current configuration using:
$PQTMCFGCNST,R
However, these commands are not accepted by the module.
3. Commands Verified
The following PQTM commands work correctly:
PQTMVERNO -
PQTMSAVEPAR
For example:
$PQTMVERNO
returns:
2023/05/09
and
$PQTMSAVEPAR
returns:
$PQTMSAVEPAR,OK
This confirms that UART communication and the PQTM command parser are functioning correctly.
4. Current GNSS Operation
The receiver successfully tracks and uses:
GPS
GLONASS
Galileo
BeiDou
QZSS
However, NavIC satellites are not visible or used in the navigation solution.
Request
Could you please advise:
Is firmware LC29HBANR11A02S_CSA2 fully compatible with the LC29H & LC79H GNSS Protocol Specification V1.5?
Does this firmware support the
PQTMCFGMSGRATEandPQTMCFGCNSTcommands? -
If not, could you please provide the latest recommended firmware for the 7Semi LC29HBA modem?
Please share the corresponding firmware upgrade package and upgrade procedure, if available.
If these commands require a different syntax for the CSA2 firmware, kindly provide the correct command format.
Our goal is to:
Enable NavIC.
Configure the desired GNSS constellations.
Output only GGA and RMC NMEA messages.
We would appreciate your guidance and any updated firmware or documentation that can help us achieve this.
Thank you for your support.
