Dear Team,
We are currently using the Quectel L89 2.0 module and would like to retrieve the default NMEA data. Could you kindly provide us with the appropriate AT command sequence to achieve this? Additionally, we would appreciate guidance on the optimal interval at which GPS data should be read.
Additionally, we are looking for the firmware required to enable NaVIC support on the L89 2.0 module. Could you kindly share the necessary documentation or example code for this?
Thank you for your support.
