Can you pease send me EC25VFAR02A14M4G or the latest compatible EC25-V firmware I need for USB Audio Class (UAC) support?
Module: Quectel EC25-V
Firmware: EC25VFAR02A13M4G
Carrier: Verizon
Host: Linux on HP, USB modem adapter
AT interface: USB interface 2
PCM data interface: USB NMEA interface 1
Please confirm whether this exact module/firmware supports two-way VoLTE audio over USB serial PCM, and provide the required configuration and a compatible firmware package with release notes.
The audio path is not a serial PCM port. On EC25, interface 1 is the NMEA port and carries GNSS NMEA sentences only. Voice over USB uses USB Audio Class: the module enumerates as a USB sound card and exposes audio control, microphone and loudspeaker interfaces. Those are disabled by default.
Configuration to enable it
AT+QCFG="USBCFG" // check the reply first
If the reply contains nine function parameters, the UAC device can be enabled. If it returns six, the running firmware cannot enable the audio device through AT.
AT+QCFG="USBCFG",0x2C7C,0x0125,x,x,x,x,x,x,1
AT+QPCMV=1,2
ATD <number> or ATA
Format is fixed at 8 kHz, 16-bit, linear, mono. Downlink you receive 640 bytes every 40 ms, uplink you must send 1600 bytes every 100 ms.
AT+QPCMV settings apply immediately and are not saved, so reapply them after every restart.
On Linux, add VID/PID 2C7C:0125 to option.c, make sure the serial driver does not claim the audio interfaces, enable snd-usb-audio, and then use ALSA as a normal capture and playback device.
A USB adapter does not change any of this, since UAC runs over USB. The host must simply see the extra audio interfaces after they are enabled.
VoLTE must be active, as Verizon carries voice over IMS only.
AT+QCFG="ims"
+QCFG: "ims",<ims_conf>,<volte_cap>
<volte_cap> must read 1. If it reads 0, the IMS and VoLTE configuration of that build is the thing to chase, not the audio path.
I have sent the requested firmware to your email. Please check.
