I have a router with EC200A-CN module (current firmware: EC200ACNHAR01A07M16).
The modem disconnects from the SIM card after a few minutes.
Could you please provide the latest firmware and update tools for EC200A-CN?
Thank you!
My email: alexklimenko2309@gmail.com
I have sent them to your email,pls check,and I hope you can click the
for me,thx
I am facing problem with jio LTE sim card where module is facing problem with network registration, current firmware version is EC200ACNAAR02A03M1G_OCPU. Can you share the updated firmware for the same which can work for LTE volte supported sim card.
Hi,@HS_support
Sorry, the firmware of the Open version is not released to the public at present. You can create a new post to describe in detail the problems you’ve encountered. We can try to help you solve the current problems. Thank you for your understanding.
Hi @leon.bao,
I want updated at firmware of EC200A-CN which can support jio sim card. whenever I am sending AT+CEREG?, in reply, I am getting +CEREG: 2,3.
Hi,@HS_support
Could you use the following commands and share the results returned by the commands?
Thanks.
AT+CFUN=0
AT+CFUN=1
AT+CPIN?
AT+COPS?
AT+COPS=?
AT+CEREG?
AT+CREG?
AT+CGREG?
AT+QENG=“servingcell”
AT+QENG=“neighbourcell”
AT+QCFG=“BAND”
AT+QCFG=“nwscanmode”
AT+CGDCONT?
AT+CGDCONT=?
Please find the result below.
AT+CFUN=0
+CREG: 0
+CGREG: 0
+CEREG: 0
AT+CFUN=1
+CPIN: READY
+CEREG: 1, "3006", "6104901", 7
+CGREG: 0
+CREG: 1, "3006", "6104901", 7
AT+QGMR
AT+CPIN?
+CPIN: READY
AT+COPS?
+COPS: 0,0,"JIO 4G",7
AT+COPS=?
+COPS: (2,"JIO 4G","JIO 4G","405872",7),(3,"IND airtel","airtel","40410",0),(3,"Vi India","Vi India","40411",0),(3,"Vi India","Vi India","40411",7),(3,"IND airtel","airtel","40410",7),(3,"404 39","404 39","40439",7),,(0-4),(0-2)
AT+CEREG?
+CEREG: 2,1,"3006","6104901",7
AT+CREG?
+CREG: 2,1,"3006","6104901",7
AT+CGREG?
+CGREG: 2,0
AT+QENG="servingcell"
+QENG: "servingcell","NOCONN","LTE","TDD",405,872,6104901,395,38750,40,5,5,3006,-96,-10,-67,4,22,0
AT+QENG="neighbourcell"
+QENG: "neighbourcell inter","LTE",38948,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",1251,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",38900,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",1228,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",2484,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",2485,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",2502,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",2508,65535,-140,-20,-,-,0,7,24,28
+QENG: "neighbourcell inter","LTE",1251,254,-97,-17,-,-,30,7,24,28
+QENG: "neighbourcell inter","LTE",1251,150,-90,-10,-,-,37,7,24,28
+QENG: "neighbourcell intra","LTE",38750,176,-100,-14,-,-,18,7,13,24,0
+QENG: "neighbourcell intra","LTE",38750,207,-108,-20,-,-,10,7,13,24,0
AT+QCFG="BAND"
+QCFG: "band",0xd3,0x1e200000095
AT+QCFG="nwscanmode"
+QCFG: "nwscanmode",0
AT+CGDCONT?
+CGDCONT: 1,"IP","jionet"
+CGDCONT: 8,"IPV4V6","IMS","254.128.0.0.0.0.0.0.128.0.0.0.0.0.0.0",0,0,0,2,1,1
AT+CGDCONT=?
+CGDCONT: (0-15),"IP",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"IPV6",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"IPV4V6",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"PPP",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
Hi,@HS_support
It seems that everything is normal according to the log you provided.
NO, its not, You can see there is “NOCONN” in servingcell at command.
Hi,@HS_support
NOCONN means UE is camping on a cell and has registered on the network, and it is in idle mode.
But still i am not able to make ping request. problem is with internet connectivity.
Hi,@HS_support
If you want to send a ping request, please dial up to access the Internet first and use the following commands:
AT+QNETDEVCTL=1,1,1
Getting this error
AT+QNETDEVCTL=1,1,1
+CME ERROR: 50
AT+CREG?
AT+CEREG?
AT+CGREG?
+CGREG: 2,0
Hi,@HS_support
Please try to type it manually instead of directly copying. Make sure all characters are in English.
Yes, I even tried typing this command manually, but still getting the same error. Only facing this issue with jio 4g network only, airtel is working fine.
Hi,@HS_support
Please try the firmware that I sent to you via email and see if it can solve this problem.
Updated the shared firmware, Now able to get reply for QNETDEVCTL, but internet is still not working.
+QENG: "servingcell","NOCONN","LTE","FDD",405,872,137C30,396,2463,5,3,3,3C,-87,-12,-58,6,39,4
AT+QNETDEVCTL=1,1,1
at+CGREG?
+CGREG: 2,0
AT+QPING=1,"8.8.8.8",1,4
ERROR
Hi,@HS_support
Can you try “AT+QPING=?”,If it still returns ERROR, it indicates that the current version of the firmware does not support this command.
The JIO carrier only supports IPv6.
Pls try
AT+QPING=1,“2001:4860:4860::8888”
Thanks, This is working with the latest firmware.
