Request firmware for EC25EUXGR-MINIPCIE
Hi Team
Where can I get the latest firmware for EC25-EUXGR? I currently have this version installed EC25EUXGAR08A15M1G_20.200.20.200
Please note the module is the GR variant, not GA. I believe they use different firmwares
Thank you!
Also can you advise how your firmware version numbering works please. I want to be able to detect older/newer versions from each other.
Hi there,
May i know is your module is EC25-EUXGR or EC25-EUXGA?
Please see original post
Hi there,
Please find the attach FW version below:
EC25EUXGAR08A19M1G_A0.304.A0.304.zip
Please also take note on the following matters:
Hello @Firdaus,
Could you please reissue an official download link for EC25EUXGAR08A19M1G_A0.304.A0.304.zip, or advise which currently released package is appropriate? The SharePoint link above was inaccessible when I tried it.
My EC25-EUX currently reports EC25EUXGAR08A13M1G_20.200.20.200. I have not yet established its exact GA/GR ordering code, so I am requesting compatibility guidance before flashing, not assuming this package is suitable. Please let me know what non-sensitive hardware identification is needed.
Could you also provide the applicable QFlash/QFirehose version, release notes and upgrade/recovery instructions?
Separately, does any compatible release support native bidirectional 16 kHz USB UAC during VoLTE/AMR-WB calls, or is USB UAC limited to 8 kHz? I understand that receiving newer firmware does not itself confirm 16 kHz support. My related audio question is in EC25 (EC25-EUX) and UAC + VoLTE - #11 by Sergii_Povzaniuk .
An official private download link through forum messaging would also be welcome. Thank you.
Hi @Sergii_Povzaniuk
I have send a follow up email to your email address. Kindly check .
Hello Quectel Support,
I have an EC25EUXGR-128-SGNS module with the following current firmware:
Voice calls connect successfully on the KT WCDMA network under Linux, and the USB Audio Class device is detected after enabling UAC. However, there is no audio in either direction during a cellular call. Direct ALSA testing shows that captured PCM is all zeros, and a transmitted test tone is not heard by the remote party.
Could you please:
  1. Provide a new working download link for EC25EUXGAR08A19M1G_A0.304.A0.304.zip, or the latest recommended firmware.
  2. Confirm that the firmware is compatible with EC25EUXGR-128-SGNS currently running A13.
  3. Provide the correct QFlash/QFirehose tool, release notes, and upgrade/recovery instructions.
  4. Confirm whether bidirectional USB UAC audio is supported for WCDMA voice calls on this hardware and firmware.
The existing SharePoint link in this topic is no longer accessible. I have not flashed any firmware yet. I can provide additional non-sensitive diagnostic information if required.
Thank you.
Dear Customer,
I have sent the request firmware and tools in your email together with the answer of question 4. Please check your email.
