Request Factory Firmware and QFIL Package for SC20ESA-8GB-STD
Hello Quectel Support,
I have a Quectel SC20-E module with the following OC:
Module: SC20-E
OC: SC20ESA-8GB-STD
Platform: Qualcomm
The module is currently stuck on the Android “Android is starting…” screen, and I would like to completely reinstall the factory Android firmware and use this module as a development/test device.
The original application and user data do not need to be preserved. A complete factory re-flash is acceptable.
Could you please provide the correct factory firmware package specifically compatible with SC20ESA-8GB-STD, including:
  1. Full factory Android firmware
  2. prog_emmc_firehose*.mbn
  3. rawprogram*.xml
  4. patch*.xml
  5. All required boot/system/vendor images
  6. Windows USB driver for SC20-E / Qualcomm HS-USB Diagnostics 9091
  7. QFIL or QFlash flashing/recovery instructions
My Windows PC currently detects the module with:
USB\VID_05C6&PID_9091&MI_00
USB\VID_05C6&PID_9091&MI_01
USB\VID_05C6&PID_9091&MI_02
ADB can also detect the device, but it shows:
cc780690 unauthorized
Therefore, I cannot authorize ADB because Android does not complete startup.
I already have Quectel QFlash V8.0 installed, but Windows currently does not show the Qualcomm HS-USB Diagnostics 9091 (COMxx) port because the appropriate SC20 USB driver is not installed.
Please provide the appropriate factory/QFIL firmware package and Windows USB driver for SC20ESA-8GB-STD.
If there are different firmware versions for Android 7.1 and Android 8.1, please advise which factory firmware is recommended for this exact OC before I flash the module.
Thank you.
Dear, customer:
Please share your email, we can provide Android 7.1 version to you which is main baseline for this module.
If you got the device developed by other vendor, the default firmware did not contain driver for LCD/sensor and other peripherals.
